HHR-SS Frt. end alignment specs.
Old Sep 27, 2012 | 11:26 PM
moonsign's Avatar
Going to be installing my coilovers soon. Coilover caster plates are set a zero now. Need to know what degree caster I need to dial in. Thanks "Moon"
Old Sep 28, 2012 | 12:37 AM
I'm glad you are doing these first, here is the report from an alignment on mine hope the number you are looking for is here. Ha Ha, this might be hard to do since it was my ford truck. Let me see if I can find the right one.
Nope I didnt' keep them they said it was right on, give them a ring.
I didn't think they would need adjustment there ?
Old Sep 28, 2012 | 05:14 AM
moonsign: (you just hit your 1000th post.)
Old Sep 28, 2012 | 02:30 PM
moonsign's Avatar
Ouch! those posts just seem to pop up out of nowhere. "Moon"
Old Sep 28, 2012 | 03:11 PM
ChevyMgr's Avatar
Old Sep 28, 2012 | 05:09 PM
moonsign's Avatar
Got it. Thanks ChevyMgr. "Moon"
Old Sep 28, 2012 | 06:34 PM
Snoopy's Avatar
Hey this thread raised another question for me.
What FRONT alignment spec.'s should we use if the 2lt suspension was changed to the SS suspension, as far as struts, shocks and springs all around?
Suggestions????
Old Sep 29, 2012 | 07:12 AM
Blue_SS's Avatar
I think it's steering knuckles that define the geometry, so you would still be FE3-spec, but I could be wrong. The springs will lower it some, and may add some negative camber. There isn't that much difference between them anyway.
alexrckid
Jul 25, 2021 07:30 AM
Michael20832
Aug 18, 2008 01:09 PM
GDZHHR
Jul 24, 2007 02:03 PM
Lone Ranger
Jun 5, 2007 06:50 PM
SoCalHHR
21
Jan 16, 2006 01:04 AM
