fed up with my radio
Old Oct 10, 2012 | 07:51 PM
kemo's Avatar
Unhappy fed up with my radio
im having problems with the fm stations not cominig in i have am and had xm checked radio and antenna connections look ok i have two antennas on top of my hhr does anyone have any suggestions on what i should do thanks
Old Oct 11, 2012 | 12:35 AM
Try another antenna, or swap in another head unit.
Keep us posted on how it goes.
Ps: your posts would probably get more responses if you used some punctuation, and used sentences rather than run everything into a long string of words. Your previous post about the stereo had very few responses - might be related?
Old Oct 11, 2012 | 01:45 AM
I can't type either, so i hired somebody to fix my radio, sounds great now
Old Oct 11, 2012 | 03:47 AM
jeff schaffer's Avatar
Wink fm power booster antenna
I have a sony top of line and some stations just don't come in so i just added a $100 including install fm power booster goes on the top inside window adds 96db and now i get every station even alot of the am stations sports ect...
Or buy an alpine $500
jeff
Old Oct 11, 2012 | 10:14 PM
Chozen317's Avatar
jeff
My alpine has poor FM reception in this car. Funny the same Head Unit never had an issue in the 4 previous Chevrolet's it was in. Do you have a part number for this FM booster? So I can self install it?
Old Oct 12, 2012 | 07:44 AM
jered6323's Avatar
SS Fan, what Alpine is that? Would you recommend it? I'm looking at putting a stereo/nav system in, but am having a hard time deciding which one, because they're all crazy expensive.
Kemo, you said antenna connections look ok. Have you checked the connections behind the head unit, or just the one on the roof? If you haven't, check the connections behind the head unit and make sure nothing's loose. As far as the antenna on the roof goes, I believe the front antenna is for FM. I believe it just unscrews, so if you haven't yet, try unscrewing it and make sure there isn't any water/crud in there, and screw it back on tight.
Krusty
Jun 9, 2012 02:45 PM
capp002
Oct 18, 2011 02:24 PM
SargeRN
Oct 5, 2011 08:21 AM
Sno White
"How To" Tutorial Library
11
Aug 26, 2009 05:48 PM
KY Dave
Jul 26, 2006 04:27 PM
