Brakes and Struts
Old Feb 28, 2013 | 11:31 AM
Jasoncp2001's Avatar
Brakes and Struts
I got new brakes and rotors a year ago. 2 months after getting them put on they started making this grinding noise when I stop. They said it was because of the new stuff in brakes but they are fine. Now they are making a thudding noise when I stop. They said that I need something added to my brakes plus new struts. Has anyone else had this problem?
Old Feb 28, 2013 | 12:19 PM
ChevyMgr's Avatar
Who is they? Find another shop to look at your brakes. Most shops will check them for free. But don't go to a brake specialty shop, they will rip your head off with extras.
Old Feb 28, 2013 | 01:01 PM
solman98's Avatar
Is this the same shop that installed the brakes a year ago?
If yes, with the quality of work they seem to do, It's no worry you went back.... Bet they like that.
Old Feb 28, 2013 | 06:18 PM
It does sound like struts or springs to me.
I wonder what "something" can be added to the brakes. If that is all that you take away from a mechanic, then you need some learning. An educated consumer is a bad mechanics worst enemy. (other words edited out).
Old Mar 1, 2013 | 01:09 AM
finnhhr's Avatar
if thudding sound when braking is hard, it sounds like the discs might be warped?
try braking from highway speed to slow speed several times in row, to make them hot and they might straighten a bit (make sure no one is behind)
Old Apr 26, 2013 | 07:26 PM
frdfandc's Avatar
When braking and the thudding sound happens, does the steering wheel shake? Or does it feel like it's coming through the seat?
Steering wheel shake - front rotors warped - either resurface or replace rotors
Feeling through seat - rear rotors/drums warped - either resurface or replace rotors/drums
Old Apr 27, 2013 | 02:34 PM
VinceP's Avatar
Just another thought. Depending on the thud it could be control arm bushings.
Old Apr 27, 2013 | 04:22 PM
The OP hasn't been back since his original question....2 months.
Oldblue
Nov 24, 2013 11:18 AM
JJfly
Sep 15, 2013 08:31 AM
mrarff
0
Jan 7, 2011 08:15 AM
fastsuv
27
Jun 7, 2010 07:49 AM
