Swaybar Question
Old Apr 27, 2013 | 09:51 PM
Hotstuff's Avatar
Swaybar Question
So today I had to cut out the front swaybar links to replace them, and in the process I scored the drivers side of the front swaybar. If I want to replace it eventually my question is whether or not a Cobalt swaybar will fit in an HHR.
Old Apr 27, 2013 | 10:23 PM
Should bolt right up, most aftermarket sway bars have the same part number for the HHR/Cobalt/G-5.
Old Apr 27, 2013 | 10:36 PM
Hotstuff's Avatar
Thanks!
Old Apr 28, 2013 | 10:14 AM
You would have to go pretty deep into the 1 inch bar to cause an issue.
For those who might see this thread whilst planning the end link job, there is a shoulder on the inner end of the tip that you can grip with a vice grip and sometimes a wrench. It is hard to find, but it is there.
Old Apr 28, 2013 | 10:39 PM
Hotstuff's Avatar
All I did was score the bottom attach point for the link, on the bar itself. The flat section with the hole through it. Not to worried though as the hole it still the original thickness. And new sways fro the wrecker are really cheap!
F-16C
May 10, 2013 12:08 PM
g bonnes
Sep 10, 2012 10:10 PM
HHRNole
29
Mar 25, 2011 12:17 AM
SS fan
Dec 17, 2010 01:56 PM
Lee3333
29
Jun 21, 2006 06:58 PM
