How to power the antenna for my car pc?
Old Jun 13, 2013 | 10:43 PM
Chozen317's Avatar
Ok 1 last issue I am dealing with in my Car PC conversion.
My head unit and factory stereo is gone. Replaced by a car pc, EQ, 4 channel amp and mono block. Mp3's and movies all look and sound great. But I am trying to add my HD radio. I can not get enough signal from the antenna for my Directed HD Tuner.
I know the factory antenna is powered. I need to locate this powered antenna wire, So I can send it 12v from the PC when it is on to power the antenna for the tuner.
Anybody wanna help? I am getting conflicting information on which wire it is. Is it the Pink one of the factory radio harness?
Pic's and system update to follow after I find this last wire I need to tap. Wife is getting a little pissy I'm rolling around with my passenger seat removed. Lol
Old Jun 14, 2013 | 04:21 AM
From an archived post by navyflier...
Radio 12v___________red/white__________+___________radio harness
Radio Ground________black/white_________-___________radio harness
Radio Ignition________(GMLAN Serial Data)
Radio Illumination______gray (dimmer)_____+___________radio harness
Factory Amp Turn-on______same as power antenna wire
Power Antenna_________pink____________+___________radio harness
LF Speaker +/-________tan - gray_______+,-__________radio harness or amplifier
RF Speaker +/-______lt. green - dk. green_+,-__________radio harness or amplifier
LR Speaker +/-______brown - yellow______+,-__________radio harness or amplifier
RR Speaker +/-______dk. blue - lt. blue____+,-__________radio harness or amplifier
So it looks you can tap the pink wire for antenna power, but if that's changed one of the hardcore audio folks will chime in.
Old Jun 14, 2013 | 05:28 AM
MsBecky's Avatar
I know there is a red wire running with the antenna lead . The location is the passenger side a pillar behind the plastic trim. That would be the most info i can accurately give to you.
Greg
Updated info... The red wire i mentioned, I think it is the power supply for the rear view mirror. Very unsure and i think i gave you bad info.
Greg
Old Jun 14, 2013 | 07:49 AM
I thought HD radio had died a silent death.
Old Jun 14, 2013 | 08:04 AM
Not dead, just languishing in the backwaters along with Sirius/XM. HD radio is used by 3% of drivers, Sirius/XM is used by 5% according to industry data.
Streaming services like Pandora are now the driving force, GM expects to stop equipping new vehicles with conventional AM/FM receivers by 2016.
Old Jun 14, 2013 | 09:39 AM
wow , 2016 and no more free am / fm, I guess I just have to listen to the sounds of the engine and the tires, glad I haven't sound deadened the HHR yet!! Oh, I can still use the CD player or my I-Pod, ahhh 2 solutions
Old Jun 14, 2013 | 05:08 PM
Seen a CD store lately?
Old Jun 14, 2013 | 11:42 PM
Chozen317's Avatar
The main reason I want Radio is for talk radio and sports broadcasts. I have over 100GB of mp3's alone. Music is not what I am after, I can also tether pandora to the pc from my phone. So What I really need is FM/AM which my HD radio unit provides. If I could get enough signal out of the antenna.
Currently I get 1 FM station 98.3 some local pop 40 bull ****.
Football season is near and I have to have my Colts radio when I am stuck on the road during a game. Pfft.
Old Jun 16, 2013 | 01:13 AM
Chozen317's Avatar
SO it is the pink. 1 Last question, what kind of amperage does the factory antenna pull?
Old Jun 16, 2013 | 08:56 AM
Which factory antenna are you talking about? I don't think the AM/FM antenna is amplified. PK to the front antenna is "radio on signal". Check your PM.
BrokenHHR
Feb 10, 2026 06:35 AM
brazor06
Dec 11, 2022 07:59 AM
desmonda
Dec 24, 2014 07:43 AM
Pretzel
Oct 3, 2014 10:37 AM
rendon47
Dec 23, 2011 02:26 PM
