alignment specs
Old Jul 24, 2007 | 11:56 AM
alignment specs
Took my car in to be aligned after lowering and they asked me for the alignment specs.
I checked Eibach's website and it says nothing about this.
Any help?
Old Jul 24, 2007 | 11:59 AM
solman98's Avatar
Shouldn't they just go back to the stock settings?
I know when I did the 4/6 drop on my truck, that is all they did.
Old Jul 24, 2007 | 12:02 PM
That's what I thought.
Old Jul 24, 2007 | 12:19 PM
chingchonger's Avatar
I just got my HHR aligned at a Showcase Chevrolet (my work) and I have the print out of all the specs.
Stock:
Front Right and Left Specified Range:
Camber: -1.7 to -0.2 degrees
Caster: +3.0 to +4.5 degrees (not adjustable)
Toe: 0.00 to +0.20 degrees
Cross Camber: -0.8 to +0.8 degrees
Cross Caster: -0.8 to +0.8 degrees
Cross SAI: not specified
Total Toe: +0.00 to +0.40 degrees
Rear Right and Left Specified Range:
Camber: -1.6 to -0.1 degrees
Toe: -0.03 to +0.28 degrees
Cross Camber: not specified
Total Toe: -0.05 to +0.55 degrees
Thurst Angle: -0.30 to +0.30 degrees
Old Jul 24, 2007 | 12:23 PM
solman98's Avatar
I would try a different shop. Mine drove great after, but wasn't that far off either after the new spindles/springs were installed. Guess we got lucky with the eye setting....
Old Jul 24, 2007 | 12:53 PM
On your pickup, the spindles would compensate for any alignment variations. If you lowered it with just springs, you will get crazy camber. Toe would probably be the only thing needed to be adjusted for the front with spindles. The rear suspension alignment does not change with lowering because it has a solid rear axle.
Old Jul 24, 2007 | 01:03 PM
solman98's Avatar
That was the reason I went with Spindles/springs verses using LCA's/spings (can't use LCA's/spindles). Seems to be the best to get that 4"s on the front. I don't have the alignment sheet anymore, it was in the glove box the day it was stolen (9/8/06). Still has not been recovered, gone for good.
Correct, no 4 wheel alignment needed, if so, you bent the frame. Back was easy, excect for the notch.
Old Jul 24, 2007 | 01:27 PM
JoeR's Avatar
Here's the specs.
The only things that need adjustment are the toe and headlights if off. Front camber will go slightly negative, but not enough to worry about. Rear won't be affected at all.
Old Jul 24, 2007 | 01:31 PM
Markiemark's Avatar
SoCalHHR use to have the specs posted, because most shops did not have SPECS for HHR, at all.
They came with the Gold-Lines I purchased through SoCalHHR.
Not sure if he still around, or if that info is available, through one of the threads referencing lowering the HHR.
Later,
Mark
I will check at home, I should have them, they may be the same as posted above!
EDIT: The post above looks like what SoCalHHR use to provide!
Old Jul 24, 2007 | 02:03 PM
Originally Posted by JoeR
Here's the specs.
Were did you get your specs from?
Here's the scan from my alignment printout.
alexrckid
Jul 25, 2021 07:30 AM
moonsign
7
Sep 29, 2012 07:12 AM
Michael20832
Aug 18, 2008 01:09 PM
Lone Ranger
Jun 5, 2007 06:50 PM
SoCalHHR
21
Jan 16, 2006 01:04 AM
