vinyl grapic kit
vinyl grapic kit
has anyone ever personally installed one of these vinyl graphic kits before? the one im interested in putting on my HHR is 7 inches by 50 inches long..
and ive never done this before. any help from the OKC area out there ?
No reason you can't do it yourself. I did the sides and tailgate of my trailer by myself and it was definitely more area than the side of a HHR. Couple tricks. Don't do it if it's below about 75 degrees outside. Make sure the car is spotless clean. Tape the top to the car with masking tape to hold the alignment. Peel off the backing before anything gets even damp. Make sure you use plenty of wetting solution. The easiest stuff to use would be a spray bottle full of water with about 5 drops of dishwashing soap in it. I was told to use Ivory since it doesn't have anything like lemon or other additives in it.
thanks navy flyer. i'll let you know when i get ready to try and attempt this. i take it you work on Tinker? Does your HHR say deluxe LT on the back? if so i was right behind you this morning trying to get through the navy gate.
