2008 HHR SS manual trans clunk
I need some help ! I have a clunk noise when letting off accelerator and reapplying it , coming from what sounds like the transmission ? There is also that noise when pushing in clutch and letting out when shifting gears. . I have replaced both LCA's, struts and bushings, sway bar end links, brakes, rotors and calipers. I have also replaced top motor mount on the passenger side. If I jack up drivers side and rotate the wheel forward and reverse there is some play and it makes sort of the same sound. The transmission mounts look okay. Am I missing something ? Any clues ? I've read through alot of the articles here but they really don't describe exactly what I am experiencing. Thanks in advance for the help all !
I need some help ! I have a clunk noise when letting off accelerator and reapplying it , coming from what sounds like the transmission ? [[[There is also that noise when pushing in clutch and letting out when shifting gears. ]]]. I have replaced both LCA's, struts and bushings, sway bar end links, brakes, rotors and calipers. I have also replaced top motor mount on the passenger side. If I jack up drivers side and rotate the wheel forward and reverse there is some play and it makes sort of the same sound. The transmission mounts look okay. Am I missing something ? Any clues ? I've read through alot of the articles here but they really don't describe exactly what I am experiencing. Thanks in advance for the help all !
