Boost Gauge Availability?
My boost gauge stopped working and circuit troubleshooting indicated a bad gauge. In searching for a new one, it appears that the only one available is the Canada spec version, part no.25913086, from GM Parts Giant. Not what I wanted, but I bought one so I could have something with a moving needle. It works, but is difficult to read while driving as its unit of measure is Kpa and there are a lot of numbers crammed in that little gauge.
I would really like to find an original US spec gauge, measuring Psi. I believe the part no. is 25913085. Every parts house I’ve tried shows it as discontinued and unavailable.
Anyone have a source? If not, I would consider a good used one if any of you that have gone the Aeroforce route still have your old Gauge kicking around.
Bob
Bob
GM 25913086 Indicator, genuine OEM part
https://www.walmart.com/ip/25913086-...ress/907116520
I Googled these two sources
the other pn 26913085 must be incorrect
That’s the correct part number , no luck finding one on a Google search
https://www.chevyhhr.net/forums/www....ad.php?t=61744
