204,000= p0016
I went the total cheap route and bought the eBay kit $59.00. They ship not far from me and should be here Tuesday. We’re going to take a look the before installing, it’s says they have sold 1200+ (hopefully not to the same guy). I did do something a little off and bought the SAAB water pump. It said genuine SAAB, has the same GM part number and the casting on the body reads GM. It was only $80.00 complete with sprocket and back plate. $213.00 was net cost on the dealer pump, it looks exact. I’ll compare everything, I can and try to apply some type of rating to them. If the chains don’t look right I won’t use them. So far I’m into all the parts for $240.00 and that includes the $12 actuators.... fingers crossed. Hope she hold out until Wednesday night, it’s about 300 more miles.
Even my cheap Evergreen kit , I bought as a spare for $35.00, had GM numbers on the chains and sprockets and guides, so you should be ok.
The cam sprockets won’t be the same for your VVT sprockets
The Manual trans is a Saab unit. Period. GM had no other manual that could handle this application.
I hope your chains themselves are OEM-level. That would be highest priority. Glad you caught it, and got some help to do the work. Best of luck!
I miss mine terribly...
