bad steering knuckles
Old May 8, 2018 | 05:57 PM
Don't forget the 'Quote' button. And don't get me started about posting from a phone. The voice to text that everybody uses, and then they don't even look before they post, to see if it says what they want it to say!
Old May 8, 2018 | 09:25 PM
I always type on my IPhone 6 , never liked the voice command to text .
I always use the view full site , not the app.
I sometimes slip and hit the Post Quick Reply, by mistake , I usually catch it and edit the post.
Old May 12, 2018 | 02:59 PM
robertito's Avatar
regarding knuckles and lower control arms
hello to all who helped me.
l hope l am doing the right thing, but l found a pair of lower control arms from Amazon for an amazing price of $70 for the pair.
l checked, and they say it does fit the fe5 suspension and the ss 2.0 turbocharged.
l will know on Monday if they are a fit or not.
thanks again for the help
Old May 12, 2018 | 03:09 PM
Ah, those won’t be correct for the SS ball joints
Old May 12, 2018 | 04:04 PM
Posting a link to them and asking if they are the right ones might save you a lot of problems. Too many parts lists are not correct when it comes to parts for the SS model.
70 bucks for a pair sounds totally reasonable - NOT!!! This is sounding more like a troll than anything believable.
Old May 12, 2018 | 04:20 PM
  #26
You have the wrong control arms. The SS control arms use a ball joint with a 20.5mm stud, which matches with the steering knuckle. Non-SS use a 19.5mm ball joint stud and knuckle. Yes, many(in fact, nearly all) parts books are wrong.
The SS ball joints are not available individually.
Control Arms
- GM - P/N: 25930724 - Right
- GM - P/N: 25930725 - Left
Steering Knuckles
GM P/N 25923941 Right
GM P/N 25923942 Left
Robert, there are no correct control arms or ball joints from the aftermarket, the part numbers I gave are the only option you have.
I have not researched steering knuckles, so I don't know what is available aftermarket(I would guess nothing). As far as I know, you are the only one who has had to replace them.
Old May 21, 2018 | 07:02 PM
  #27
Blue_SS's Avatar
If you run with the wrong control arm/ball joint, you will need to replace them...
Buy the GM parts, there are no substitutes that fit right. Learned the hard way here...
brazor06
Dec 11, 2022 07:59 AM
anthony303
Oct 25, 2018 10:35 PM
MCHHR
Oct 4, 2016 03:00 PM
allij0812
Dec 12, 2013 11:16 PM
RStruthers
Jul 7, 2012 10:50 AM
