Bolt on Upgrades
well this spring i am either doing wheels/tires or a turbo kit. if i elect to do the turbo kit now i will eventually do wheels/tires......and may do a track oriented tire like 555r's or re11's...something of that nature....and use my stockers for a commuting type of wheel tire setup. in this case i will probably put regular 555's on the stock wheels. then again i may just use the new wheels and tires for my every day setup.
either way i will also have a dedicated strip setup most likely 16" slicks or mickey t et street radials
the mickey t radials.....if that's what you are referring to....i hear are the stickiest of the sticky but don't have much life. i also hear the hoosier dot drag radials are really good.
I need good traction with the power I have.
Like a dumbass, I left my best drag time slip in my wallet to show people and in about a week it went black, and with the heat, all the ones in the car went black as well. damn carbon paper, but on street tires with the basic bolt-ons It will run . a 9.579 @ 82.1.... Best 60' @ 2.4(not that run) that was with a carseat, full tannk of gas, subbox, etc.
With Mickey T's I could maybe squeeze another 3/10 of a second off that, getting my 60' in or under 2 sec. maybe
Bigger performance investment is in the future here.... The wife made a huge deal with me..... Quit smoking, and all that money will get dumped into a "toy" account..... I quit last week, Toys!
try footballs in the rear springs and chain the front springs to help eliminate squat and keep the front end planted.....i have heard the football mod works wonders
i have yet to hit the track. i have two 1/4 tracks both about 90 minutes away. one is super sticky and is know to break weak driveline parts....the other gets little to no prep so its spin city there. atlanta motor speedway does 1/8 mile but there is no tree....its a hand drop signal....and no timer so you have no clue how fast you ran. there is an 1/8 track about maybe 2 hours away that is pretty decent......but mainly my track options aren't that great and are kind of a drive. also im afraid to hit the track with my stock tranny with 101K and rising transmission
Should have said this.... 1/8 mile track, I was thinking Pedders, and making some solid bars to bolt between the A-Arms, and frame for track time, instead of chains.
I could also just use some very large turnbuckles with a couple of bushings, and bolts, to give the adjustability that I might need.
jonboyb was telling me the other day that the sway bar has a lot to do with controlling squat on this car. i don't know how true this is but he is a very knowledgeable drag racer so i will take his word for it. whenever i do the powell xxx bar maybe that will help out a bit.
