Both Control Arms in Stock Now at Rock Auto
Old Jun 13, 2021 | 09:24 AM
fastsuv's Avatar
Rock auto just got in a batch of right-side SS control arms (GM 25930724). They sent me an Email that they are back in stock. I ordered one to go with my left-side control arm that I am keeping in stock in case I need it for my SS.
Steve
Old Jun 13, 2021 | 11:36 AM
Great news, now order up a pair! They are harder to find and only fit the SS FE5 suspension. And you know they’ll be out of stock when you need a set!!
Old Jun 13, 2021 | 09:54 PM
Old Jun 13, 2021 | 10:40 PM
That's the only one they have now. They are now out of the 0725 left side.
Old Jun 14, 2021 | 06:36 AM
Just can’t win! You have to order 1 at a time when they are available
Old Jun 14, 2021 | 11:36 AM
fastsuv's Avatar
If they are out of stock on a part, just pick the selection to notify you when they get it in stock. Then order it quickly as soon as you get the Email from them.
Steve
Old Jun 14, 2021 | 11:49 AM
terryk's Avatar
Sold out. I asked for notification for both. Mine are still fine but I assume they will go south at some point. It appears they are discontinued from GM so maybe aftermarket will pick them up.
Old Jun 17, 2021 | 03:22 PM
PulpFriction's Avatar
Hope it works out! Looking forward to hearing that you received it, AND that you’ve measured the ball joint and it’s 20.5mm.
Maybe we should combine my prior thread with this (which is located in the correct place.) Mine I put in General hope some non-SS owners would see it too, and kind of expecting it to get moved.
Old Jun 17, 2021 | 04:53 PM
lazaino's Avatar
I wonder if we can convince Moog to make a run of their K80567 with 20.5 studs, that would solve the problem. How much interest is there? How many SSs are left?
Ira
Old Jun 17, 2021 | 05:05 PM
Problem is MOOG doesn't know the part number for the ball joint, so they couldn't specify. If the stud is different it would be a different part number. As far as they know their catalog is correct even though we know otherwise.
