Bpv stuck code
Old Nov 27, 2024 | 03:05 PM
O6ChevyHHR's Avatar
Bpv stuck code
Hey guys
anyone ever get the stuck bpv code after installing a new aftermarket bpv. I installed the Zzp billet bpv and it works great it just throws a check engine light every so often. Contacted Zzp and they told me to bypass the vacuum res I did that and no more code at least for the moment.
Old Nov 27, 2024 | 04:46 PM
Codes have numbers not names. Pxxxx etc. Every code reader might have a different name/description, the numbers are constant.
Old Nov 27, 2024 | 06:42 PM
O6ChevyHHR's Avatar
P2261 is what I’m getting on my snap on scanner
Old Nov 27, 2024 | 08:07 PM
There are a number of search results here on the site for that code.
Old Nov 27, 2024 | 08:42 PM
Here is a part of the description of what the BPV and tank do. Maybe, the ZZP part does not need the instant source.
Old Nov 28, 2024 | 12:14 AM
O6ChevyHHR's Avatar
Thanks I bypassed the tank and so far no code so it might be a missus with the tank. Going to drive it a few days and see what happens.
Old Nov 28, 2024 | 08:21 AM
PulpFriction's Avatar
I had P2261. Once. Just watched the boost for awhile. Went away. Never saw it again.
Old Nov 28, 2024 | 09:49 AM
I ran the Forge Motorsports aluminum bypass valve for many years on my SS. Never any codes or problems using their “yellow” spring setup.
Does the ZZP come with different springs you could try ?
Old Nov 28, 2024 | 12:01 PM
O6ChevyHHR's Avatar
yes it comes with 4 springs a green yellow blue and red. I currently have the pre installed green spring. They said this is best for stock setup. I did contact them and they told me to bypass the vacuum tank so I did and so far no codes. It didn’t do this with the stock bpv.
Alkost01
Jan 14, 2026 10:28 PM
Trumpet1
Jan 31, 2025 05:00 AM
cj-five
Drivetrain (Excluding Engine)
Sep 21, 2024 09:59 PM
Steve Gilbert
2.0L Performance Tech
Oct 24, 2017 06:11 PM
08SSREDHHR
Aug 22, 2012 10:04 PM
