Broken keyway in crankshaft
Old Mar 21, 2021 | 03:21 PM
Namnevele's Avatar
Hello everyone. I recently purchased a 2008 HHR SS auto. I noticed a squeak under the hood that led me to a wobbly harmonic balancer. Upon removal I found the crankshaft key broken off flush with the cam gear. Just wondering what the best way to fix this would be. Thanks in advance!
Old Mar 21, 2021 | 04:26 PM
Your gonna need to remove the chains and sprockets, you may possibly pop the key out with a chisel or punch , be very careful not to damage the block or crankshaft. The crankshaft sprockets are very different from the 2.2 or 2.4, they are not available from aftermarket.
Old Mar 21, 2021 | 05:42 PM
Figure out how that happened so it doesn't repeat. Look like it may not be the correct size key.
Old Mar 22, 2021 | 07:14 AM
It might be the wrong sprocket
Cubapapa
Dec 17, 2020 07:30 AM
Dave Priebe
Dec 25, 2014 05:14 PM
hursst
Maintenance and Upkeep
May 24, 2013 05:42 PM
SmootHHR
"How To" Tutorial Library
21
May 27, 2011 01:43 PM
dbarberaz
May 4, 2006 09:44 PM
