A/C problem
Old Jun 11, 2012 | 02:43 PM
Just to add. "prolly 55° air." That is not really cold enough. Should be in the 40-45 degree range on max air.
Old Jun 11, 2012 | 08:07 PM
Spozo's Avatar
Duct outlet temp is dependent on ambient humidity and temperature, in that order. At this point, I think the compressor was probably replaced for no reason, and would be concentrating on airflow through the condenser, or more likely, an electrical issue with the high pressure sensor.
Old Jun 11, 2012 | 08:25 PM
Very true spozo. I'm old school and still keep my pocket thermometer stored in one of my car's AC ducts. 40-45 range is usually noted while my car is in motion.(airflow through condensor, higher AC pump pressure)
I also live in a high temp,very high humidity area. I think that B Diggity's quote of 55 degrees is either at stationary idle or he's got other problems.
Old Jun 12, 2012 | 11:52 AM
Originally Posted by B.Diggity
Kay forgot to update.
They replaced the compressor. Yay. Worked for one day.
I haven't seen the a/c clutch enguage/disenguage. And now, when I touch the gas pedal, it feels and sound like power steering pump is bad. Buut there is no ps on here. Won't be back in shop til friday. really getting tired of it being broken lol. It does blow cold air, prolly 55° air. But that whine is bad. Maybe the belt?
Thank you for the update. I was hoping things would be resolved so you can fully enjoy the Summer time in your HHR. Please, refresh my memory; you are having the work done at a dealership?
Old Jun 15, 2012 | 09:15 AM
B.Diggity's Avatar
Yea at jupiter chevy. N to the rest, I agree. Hopefully they figure it out today. N they replaced the compressor due to it blowing out the freon. But I do think something else is causing the problem.
Edit
Due to the recent weather down here, its not wanting to act up at all. So next day its warm they hopefully then can figure it out
Old Jun 18, 2012 | 10:40 AM
Edit
Thank you for the updates. I hope they are able to get this resolved for you soon, but keep me in the loop.
Old Aug 5, 2012 | 10:19 AM
REDSEDANDELIVERY's Avatar
this may sound dumb but check the radiator cooling fan and make sure it turns on when the a/c is switched on. My friends wife had the compressor changed and the problem started again. stop and go traffic, Yes it was burnt wires / connector to the fan. I cut out the jumper and problem solved.
There should be a recall for the jumper / extension wires... it's just poor customer service not to.
Old Aug 6, 2012 | 10:23 PM
IgottaWoody's Avatar
Probably didnt change the filter/oriface...now all the junk is in the new compressor...or he got one of those 'really sweet deals' compressor at the local family dollar parts store emporium....
urbexHHR
Nov 3, 2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
suburbanjunior
Apr 1, 2008 01:12 PM
Black Rose
Dec 7, 2007 11:28 AM
