Can't find a front wheel hub spacer
Old Feb 29, 2024 | 02:44 PM
johnk's Avatar
Question Can't find a front wheel hub spacer
I'm sorry if this is posted somewhere, if it is, I couldn't find it. I also can't find a "steering knuckle bearing spacer" part # 25794670 to purchase. It's discontinued by Chevy/gm and I haven't been able to find an aftermarket alternative. (Had the car front end torn apart to replace all bushings/bearings, etc, and must have accidentally tossed one of the spacers. Gettin old!) Any ideas of where I could find one? Thanks for the help!
Old Feb 29, 2024 | 02:56 PM
Was there one installed? That was a discontinued "fix" for splash guard. Not required, not really a spacer.
Probably not there to start with the other one was likely found somewhere.
Old Feb 29, 2024 | 03:43 PM
I’m sure others have already not reinstalled that piece, me for instance, it is real thin didn’t make a difference.
Old Feb 29, 2024 | 08:45 PM
Pick one up used?
Old Feb 29, 2024 | 09:27 PM
IIRC, they were only on 2008, 2006-2007 had a full shield. The full shield caused over heating rotors and the smaller one didn't do anything.
They disappeared on my 2008 and not on my 2011.
Old Mar 1, 2024 | 06:12 AM
My 2007 LS had these and my 2011 2LT has the full splash shield.
used at a pick a part is a good source.
Old Mar 1, 2024 | 05:48 PM
johnk's Avatar
Thanks for all the responses! I thought it was a "spacer" that was needed to locate the rotor in correct alignment with the caliper???? I'll try to mount it without the spacer and see how they line up.
jeffros hhr
Oct 10, 2019 08:35 PM
james1767
Aug 11, 2019 09:03 PM
jbiesent
44
May 9, 2016 12:11 PM
Beaglelover
16
Sep 25, 2014 08:40 AM
dudley
Apr 14, 2012 11:06 PM
