Chevy HHR won't start. Code p0336 + Additional Codes
Old 07-03-2016, 02:47 PM
Jmusi09's Avatar
Check engine light came on in my hhr ss. They are p0650, p0442, and p0496. Any suggestions on how to fix these or what may cause them?
Jmusi09 is offline
Old 07-03-2016, 03:04 PM
Welcome - Give the search tool at the top of the page and look for the codes - ie: p0650 - which brings up this page will get you started on the diagnostics - https://www.chevyhhr.net/forums/prob...e-p0650-48939/
(I'm on a rather sporadic wifi here otherwise I'd give a few more links for you)
whopper is offline
Old 07-03-2016, 03:07 PM
p0442 - https://www.chevyhhr.net/forums/prob...e-valve-44428/
whopper is offline
Old 07-03-2016, 03:22 PM
Jmusi09.
Your info shows your car as a 2007 HHR SS. They didn't make a SS in 07. Could you clarify the year and model you do have ?
firemangeorge is offline
Old 07-03-2016, 03:54 PM
p0442 could be just the gas cap.
BUT, the combo of P0420 & P0650 indicates a strong probability of a dead catalytic converter. Especially if the light is flashing.
Just to rule things out; check the underhood fuse box #33 & #64.
donbrew is offline
Old 07-03-2016, 05:53 PM
Welcome to the site! I'll hold back until you clarify the information requested above
Oldblue is offline
Old 11-15-2016, 02:29 PM
Jmusi09's Avatar
Chevy hhr won't start. Code p0336
Last Wednesday I was leaving work in my 08 hhr ss when the "engine power reduced" message popped up and my car then shut off and will not start up. I ran my code reader and it reads p0336 crank shafts sensor. Could that be the cause of why the car stopped running? Please help
Jmusi09 is offline
Old 11-15-2016, 02:34 PM
Sound like your timing chain broke.
donbrew is offline
Old 11-15-2016, 02:37 PM
Jmusi09's Avatar
Would that make that code come up?
Jmusi09 is offline
Old 11-15-2016, 03:01 PM
Yes, as the symptom show in this link
https://www.obd-codes.com/p0336
When the chain breaks the cams are out of sync with the crankshaft, the ECM shuts down the ignition to prevent further damage.
Oldblue is offline
Quick Reply: Chevy HHR won't start. Code p0336 + Additional Codes
