Compression test, piston rings, head gasket
Old Jan 21, 2023 | 05:43 PM
All 4 the same?
Old Jan 21, 2023 | 08:06 PM
hhrumadbruh's Avatar
Originally Posted by donbrew
Are the plugs oily or steam cleaned or just a nice brown. https://www.mobil.com/en/lubricants/...ck-spark-plugs
dark black around the relatively new spark plugs
Even with variations in readings if you were to try a different tester, that's pretty low compression. A healthy engine would be around 180, plus or minus. 100 would be bad.
Let's see what the other cylinders say, but I'm guessing you're heading to a leak down test.
Have you tried a "wet" test yet? That's usually good for diagnosing rings.
All cylinders 130psi. Pour 5w30 into each spark plug hole?
Originally Posted by Oldblue
All 4 the same?
yes, 130/135 psi
Old Jan 21, 2023 | 08:28 PM
Pour a couple of tablespoons of 5W30 into each spark plug hole and do the compression test again
the rings might be carboned and sticking
Old Jan 22, 2023 | 04:33 PM
PulpFriction's Avatar
Everything says this thing is running very rich at high vacuum if not all the time. Wonder if it had a tune you didn’t know about. Wonder if it is an E85 ro E47 tune. (I have no idea how to figure that out.)
Your car doesn’t by any chance have blue MAP sensors or a “premium 91 only” sticker at the fuel cap, does it?
Now I’d want to look at the injectors and see if they’re stock. Also maybe use you bluetooth dongle and app to chart fuel pressure, a/f, and 02 voltage all together while making white smoke.
Old Jan 22, 2023 | 04:40 PM
The white smoke did seem to appear more when I put 91 in it...but I don't know how relative that is. I haven't been driving it hard at all. I hit 3k a few times and 4k once or twice.
Old Jan 22, 2023 | 10:15 PM
greg8453's Avatar
Do a running compression test.
Old Jan 22, 2023 | 11:10 PM
How do I do that?
I swapped the oil for 10-40 with 1 quart of Lucas oil stabilizer and the smell went away and most of the exhaust smoke did too...hmm...might be rings?
Old Jan 23, 2023 | 08:03 AM
Did you do the table spoon compression test?
Yes the rings might be carbined and sticking
Old Jan 23, 2023 | 09:17 AM
Add a tablespoon of oil to to each cylinder before compression test? Not yet.
this might be a dumb question but is the turbo hooked up to an oil line? Or just coolant?
Old Jan 23, 2023 | 09:44 AM
The turbo has an oil passage and return line
