Compression test, piston rings, head gasket
Old Jan 24, 2023 | 07:29 AM
  #31
Usually bad intake valve seals cause a puff of blue smoke on startup, then at highway speeds if you lift off the throttle quickly.
Old Jan 24, 2023 | 08:59 AM
  #32
All this is good information, but I cannot recall anyone here on the site reporting that they had bad valve seals. Common Chevy problem? Maybe, but this engine is (mostly) not designed by GM.
Old Jan 24, 2023 | 09:18 AM
  #33
In all my time working on Ecotec engines, I’ve only replaced valve seals when replacing bent valves, because they came in the head gasket kit.
Old Jan 24, 2023 | 10:33 AM
  #34
hhrumadbruh's Avatar
I do notice the cloud of smoke when letting off the pedal hard. Does not happen when I still have some throttle. I'm not sure if this matters. Its only when I go from psi to vacuum. Sorry not familiar with turbo motors. A lot to take in.
Unrelated (posted a new thread) would a bad cat cause any of this?
Old Jan 24, 2023 | 11:41 AM
  #35
No, it wouldn’t, but this could cause a bad catalytic converter!
Good cat!
Jfidelh
Mar 26, 2023 04:27 PM
ptolene
Dec 18, 2014 09:00 AM
ULOS2A6
2.0L Performance Tech
Jul 10, 2014 01:31 PM
divezonescuba
Oct 1, 2013 03:56 PM
bandit12
Jul 17, 2006 04:15 PM
