Engine Rattle During Acceleration
Old Jul 27, 2022 | 07:48 PM
Sometimes the camshaft phasers can loosen up and have a rattle, I’d look at the serpentine belt and tensioner, pop the valve cover and check the front guide! Did you install the replacement bolt ? The OEM bolts can vibrate loose and shatter the black plastic guide.
Old Jul 28, 2022 | 09:27 AM
m_ridzon's Avatar
Originally Posted by Oldblue
...and check the front guide! Did you install the replacement bolt ? The OEM bolts can vibrate loose and shatter the black plastic guide.
No I did not install the replacement bolt. I have done my chain about 3 times since I've owned the car. I've inspected that bolt each time. It looks perfectly fine and has never showed any issues. I put Loctite on it when I reinstall it, so it hopefully doesn't loosen. But I'll definitely check.
Old Jul 28, 2022 | 10:33 AM
A little loosely goosey and the front guide is toast! Just saying, never ever think it’s ok cause you just changed it resently
Old Jul 28, 2022 | 10:42 AM
m_ridzon's Avatar
Agreed! And that's why I'll inspect it when I'm in there.
Old Jul 28, 2022 | 01:09 PM
Double check the timing chain tensioner is engaged, while you’re in there !
Old Jul 28, 2022 | 04:56 PM
PulpFriction's Avatar
First and foremost, do not assume the front guide is intact just because it’s newish. While plastic does fatigue, it can shatter anytime if it’s bad plastic or subjected to high rpms. Roller chains suck for high speed and rattle like crazy. The latest Ecotec has an inverted-tooth timing chain.
Supply chain issues have turned fuel quality to crap. Suppliers are excusing themselves and regulators have played along. Even “Top-teir” seems to be accepting excuses. Poor detergency in fuel leads to carbon deposits in the chamber, leads to carbon hotspots, leads to knock.
Try some Shell 93 or other top-shelf asap, maybe detergent fuel additive, still takes awhile to work, use a light foot and lowish rpm in the meantime.
Check for codes, but maybe a knock sensor, anyway.
Even with de-coking, tricky to get valves clean near the guides. Sticking valves.
Bad lifter(s). Or rocker(s). Or something loose. Or broken. Hard look under the valve cover?
Old Jul 28, 2022 | 05:01 PM
I did see that 76 gas labeled their fuel pumps as Top Tier fuel, when I filled up in Florida and Georgia and North Carolina
Old Jul 28, 2022 | 05:07 PM
“Top-tier” sticker disappeared from my Shell station pumps for awhile. Noticed it’s back.
Gonna hit all my cars with some detergent fuel additive.
Forgot to mention the possiblity of piston slap or rod knock from plain ‘ole engine wear.
Old Jul 28, 2022 | 06:48 PM
My niece insisted that her oil change guy said Dino oil was the. Best 10w30 never let him down, her 2009 Sierra , just threw a rod out the block only 238,000 kilometres on the odometer, I just changed the transmission cooler lines! Time for a new crate engine!
Old Jul 28, 2022 | 07:35 PM
Just get a new connecting rod and some JBWeld!! Good as new!!
