Gaps in Hood and Tailgate - Fix?
Old Oct 22, 2016 | 10:50 PM
06HHRDUDE's Avatar
Here, CLOSE this one too!
Old Oct 23, 2016 | 01:56 PM
Check the drivers side bump stop , it's adjustable, mine was out 5/16 of an inch
Old Oct 24, 2016 | 01:08 AM
06HHRDUDE's Avatar
Old Oct 24, 2016 | 10:00 AM
Yes they're the rectangular rubber bump stops on the sides.
Old Oct 24, 2016 | 12:10 PM
I seem to recall in another thread of your's that one of your liftgate struts was broken off.
Hope that the liftgate itself isn't bent or warped because of that.
Old Oct 24, 2016 | 12:30 PM
Silverfox's Avatar
On the hood adjustment lower the bumper on the high side, then drop the hood down and close it
If that side is still high, manually push the hood downward to see if it is not seating on the lowered bumper. If not then you may be too low on the bumper or need to make a small adjustment downward on the hood latch as well.
I mark the current latch setting with masking tape on the edges of the latch plate so you can see how much you have moved the plate in either direction.
I take extra time in adjusting to get any issues as close as I can so don't be in a big hurry. The front of the hood is the only reasonable adjustment available.
When done. grease the front latch contact points.
I also put a dab of silicone grease on all the hood rubber bumpers.
Do you have a Carfax or Auto check that shows if this HHR has been in any accidents?
These issues could be the work a some Sloppy body shop in the past.
SF
Old Oct 24, 2016 | 02:26 PM
06HHRDUDE's Avatar
Old Oct 27, 2016 | 01:17 PM
You could try loosening BOTH stops then close the gate. Remember: one out will force the other in.
Visually inspect the hinges, if 2 thing rusted out maybe 3 things did.
Old Oct 27, 2016 | 02:19 PM
06HHRDUDE's Avatar
oldracer
Dec 18, 2015 10:03 AM
taz3
Dec 28, 2014 02:18 PM
American & Proud
Mods - Exterior
60
Jun 26, 2012 08:13 AM
GregW
Jan 10, 2009 10:18 AM
