HHR SS needing a headgasket already?!
Old Feb 13, 2012 | 05:03 PM
ChevyMgr's Avatar
I'm lost. Did they put a head gasket on and then it leaked coolant and oil onto your garage floor? When you put cleavage and coolant in the same sentence I get confused.
Old Feb 14, 2012 | 02:02 AM
SOMBERSHARK0714's Avatar
Wow, we have 43k on ours & we have had our '08 SS new in Feb. '08. No probs like that. Good luck w/ everything !
Old Feb 14, 2012 | 05:49 AM
hyperv6's Avatar
Head gasket failures are not common. There are few engine of any make I have not seen a failure with at some point. You always see a few failures on all of them. My buddy has made a good living on Civic gasket failures.
We have seen a couple here but very few gasket failures on the 2.0.
You are under warranty and they will fix it.
Old Feb 14, 2012 | 09:28 AM
penning4544's Avatar
They replaced the headgasket and then it overflowed from the coolant resivoir, I guess they didn't do enough heat cycles. I'm also noticing oil leaking on the garage floor, probably from removing the oil pan to check for coolant leaks between cyl #2 and #3 after the gasket replacement per the tech help line. Good thing I bought extended warranty, I have a feeling that's going to pay for itself.
Old Feb 14, 2012 | 09:36 AM
07azhhr's Avatar
Sorry you are having engine issues. Just an FYI that others keep trying to tell you above is that we have 100,000 mile 6year powertrain warranties. This means you are covered by GM themselves still. Also since the dealership did the work they HAVE to fix it for you anyways if it is directly their fault. But either way they will just bill it to GM so you have nothing to worry about. And I keep reading of new engines so feel lucky cause you will probably get one.
Old Feb 14, 2012 | 11:31 AM
Originally Posted by 07azhhr
Just an FYI
Thought it was 5 year or 100K.... not 6 year ?
Old Feb 14, 2012 | 12:51 PM
bigjacksauto's Avatar
Originally Posted by 843de
Well unfortunately the SS model is a bit high strung and persnickety as the owners here can tell you, but losing a head gasket this early might just be "one of those things". My concern would be damage to the rest of the engine, bearings don't like a mix of coolant and oil, I seem to recall others in similar situations getting new engines under warranty.
So I am assuming that the hhr ss is not as reliable as the 2.2 or 2.4?
Old Feb 14, 2012 | 03:55 PM
hyperv6's Avatar
First off you may have some air in the system. The HHR is a little more difficult to bleed the air out of the system and some people and even tech don't always do that right. If your temp is good I suspect air in the system.
As for Oil I would have to see what you have to make the best call but after having an engine appart it is common for some oil drips. They can wipe it all down and you will still get some oil drips.
At this point I would not get in too much of a panic yet.
Old Feb 14, 2012 | 03:58 PM
hyperv6's Avatar
Not really any more or less than the other the other engines. To be honest I see more issues with them but percentage wise they all seem about the same even with the added turbo parts.
The Eco is as durable 4 cylinder out there. I see many more issues with other 4 cylinders.
There never has been a perfect engine but the Eco does really well on the whole and the 2.0 is no worse.
Old Feb 14, 2012 | 06:48 PM
07azhhr's Avatar
Sorry my bad thank you
