HHR SS needing a headgasket already?!
Old Feb 14, 2012 | 10:29 PM
Originally Posted by bigjacksauto
So I am assuming that the hhr ss is not as reliable as the 2.2 or 2.4?
Not less reliable as a whole, and I'm sorry that it came out sounding that way, but they are more sensitive to maintenance and performance mods.
By its nature and construction the 2.0 Ecotec is one tough little engine, it has to be in order to survive the rigors of being a small displacement turbocharged power plant.
Where the SS models can get touchy and persnickety is when they are modified with anything from the Stage 1 kit from GM to assorted aftermarket tuning programs, etc.
And as with any other "performance" vehicle, you can run into problems that are particular to them only, where the "everyday" versions have their own issues particular to them.
Old Feb 14, 2012 | 11:12 PM
Originally Posted by hyperv6
As for Oil I would have to see what you have to make the best call but after having an engine appart it is common for some oil drips. They can wipe it all down and you will still get some oil drips.
Really ?? Not if it is correctly assembled.. Older engines used to be harder to seal up, with less precise tolerances..
Old Feb 14, 2012 | 11:19 PM
Oil drips might be expected on something like my 75 year old Chevy truck, but not on an HHR, if its leaking they messed up....plain and simple.
*For the record, the '37 does leave a half dollar sized spot of oil after a drive, those old rope seals on the rear mains of 216 Stovebolt sixes do that. I could yank the engine and change it to a modern one piece seal, but that thing has been dripping like that for 3/4 of a century now, got to let it have some fun.
Old Feb 14, 2012 | 11:39 PM
"For the record, the '37 does leave a half dollar sized spot of oil after a drive"
That assures ya it has oil, by marking it's spot.
Old Feb 15, 2012 | 01:02 AM
And its much more polite than peeing coolant on fire hydrants.
Old Feb 15, 2012 | 08:19 AM
  #26
bad03xtreme's Avatar
Pics of the cleavage???
Old Feb 15, 2012 | 08:34 AM
  #27
here's one I thought was particularly nice. I hope they aren't leaking too.
Old Feb 15, 2012 | 09:26 AM
  #28
And for the umpteenth time this week, Sam's wholesome image goes right out the window.
Old Feb 15, 2012 | 09:43 AM
  #29
07azhhr's Avatar
I think Hyper might be refering to oil that got on parts of the car outside the motor and form puddles if you will. When the car is driven this oil will be blown onto other parts of the car or simply off the part it is on and then they will drip from there. These are sometimes hard to see from under the car and can be missed by the tech after reassembly clean up. A good steam of the engine bay after a job like this is what my old dealership would do to prevent this kind of come back. In these cases there is nothing wrong with the work performed but the car owner will think otherwise.
Old Feb 15, 2012 | 10:11 AM
  #30
No steam cleaning for me. With all the electronics in these cars I'm not taking any chances.
