IC piping/ warranty
Example: Installing an aftermarket muffler can not be the cause of your intake manifold leaking.
Would be surprised if they would install, but regardless, my above rule applies. If the piping did not cause the failure, it does not void the warranty.
If your brakes fail, they can not blame your piping as void of warranty. If you blow a cylinder due to overboost etc,.....well that's a different story...maybe arguable....but I highly see that you bettering your airflow would blow a forged internal engine......
.....I would think you would need other add-ons.....else mine would have blown!
