Intermediate steering shaft
On another note, would a non-SS rack and pinion happen to fit on an SS? That's where the splines are different compared to the non-SS models. Whyever GM decided this was a good idea is absolutely beyond me.
Robert
I've thought about this, as well. If the steering ratio is different, it might mess with the active handling while driving it. A major part of that system is the steering angle sensor, which I believe is located in the EPS module above the intermediate shaft. It would see the extra turning of the steering wheel, but not as much change in direction of the vehicle and activate, thinking you're sliding the front end.
Robert
Robert
Traction control is engine torque management, which is used in conjunction with active handling. I'm talking about the part of the system that uses individual brakes at each corner to ensure the car goes exactly where you steer it.
A: do the two pieces of each shaft slide apart? Is it plausible to just replace the bottom half?
B: if it’s the upper yoke that’s different from the LS/LT then could you just swap the top yokes?
C: I don’t know the exact dimensions of these bearing caps but there is a possibility of replacement u joints as this guy did
https://youtu.be/sMjNVNUewDY
C: That video is where I got the idea from, actually.
Machine shops used to do that sort of thing every day. Cut a piece of metal weld another piece on. Pretty much the reason to invent the lathe parting tool.
If the bearing caps are the same, you have the parts to rebuild. Or, one more time, Machine shops know where to get special bearings.
