knock sensor
Old Oct 13, 2017 | 05:22 PM
Supafly94's Avatar
knock sensor
So my weekly check engine light came on , P0332 knock sensor. Does anyone know where this is located, and is it easily changed? (09 SS Manual)
Old Oct 13, 2017 | 05:30 PM
The knock sensor is just above the starter, check for a loose connection first
https://www.obd-codes.com/p0332
Old Oct 13, 2017 | 07:02 PM
and torque it down to 25 N.m or 18 lb ft as per shop manual if you need to replace it
Old Oct 13, 2017 | 07:39 PM
I think the LNF has 2 Knock Sensors. P0332 in #2 (11 in the pic) If you care to test things before throwing parts at it I may be able to help. It would be strange for one to break, they are basically electret microphones.
Here is the testing procedure:
Numbers 7 & 11 in this:
Old Oct 14, 2017 | 08:09 AM
DrLoch's Avatar
It does have 2. I've not heard of one going bad, not to say that they don't. As suggested I'd check the wiring.
Old Oct 14, 2021 | 11:38 AM
Supafly94's Avatar
Do you have to access this from under the car?
Old Oct 14, 2021 | 12:24 PM
Wow, 4 years later!
Haynes says to remove the alternator for access to the front knock sensor.
Old Jul 6, 2023 | 03:46 PM
hhrumadbruh's Avatar
I took the starter off again. I was wrong about what I saw last time. Its not a knock sensor. I cant see a way to get to either of the sensors from the bottom of the car.
What do I need to remove to access bank 1 sensor?
I'm assuming that's the sensor behind the oil filter? Could I just get an extension and swivel in there?
Old Jul 6, 2023 | 05:48 PM
Well I got the driver side knock sensor swapped out. Those little extendable mirrors really helped. Here's some pics of how I got in there. Hope these could be of some use to other people. The sensor is located just behind the dipstick tube (correct me if this is incorrect, I think it might be a brace bar) and the oil pressure sensor.
I used a 1/4 (2/8) ratchet with extension and swivel. You can identify them in each picture for location reference.
The new oem sensor was 1/2" and the old sensor was 10mm
Old Jul 6, 2023 | 08:25 PM
This is the first time you've posted in this thread, did you mean to post in one of your threads?
There is only 1 bank on an inline engine, so both knock sensors are bank #1. I don't know what code you have, so I can't comment which sensor is giving you problems.
will1528
Jun 17, 2023 06:09 PM
RJ_RS_SS_350
Aug 17, 2022 06:45 AM
fanbelt.1
Jul 8, 2018 08:08 AM
douglas
2.2L Performance Tech
12
Mar 4, 2018 04:09 PM
DaneyKakes
Feb 6, 2012 03:41 PM
