Local mechanic doesn't know what to do??
Old Apr 17, 2024 | 03:07 PM
hhrumadbruh's Avatar
"Never messed with a turbo before" ??? !!!
At least they're honest.
Turbos are pretty common in the 21st century.
Why is your car there?
well I'm guessing they thought they had an idiot who would spend $400 in parts and labor for $80 in parts and 30 minutes in labor. And I'm also guessing by the technical questions I was asking that they realized I had an understanding of how the engine works and wouldn't be easily fooled or scammed and decided not to test the waters on me?? No idea.
Just realized my new phone doesn't mess up the layout of the post when I add images so here's a picture celebrating that
Old Apr 17, 2024 | 03:08 PM
Originally Posted by Oldblue
I’m looking for coolant ports , don’t see where the coolant hoses connect, I looked a the Cobalt site and now see the coolant lines.
Thanks RJ
I think one of the top banjo bolts on the turbo is a coolant line going to the thermostat housing. I replaced that bolt and washer recently.
Old Apr 18, 2024 | 09:30 AM
greg8453's Avatar
Originally Posted by hhrumadbruh
I do notice a bit of steam when starting the car. There is a decent amount exhaust water in the muffler. Someone had drilled a hole for a drain. It was clogged and I used a screw driver to unplug it. I would say about a cup of water had drained when I did that. It was odorless and clear. I wonder if that would be from the turbo burning up some coolant? Or something else? My 2010 LT with 225k never had this issue at all.
Condensation is normal.
Old Apr 19, 2024 | 11:00 AM
PulpFriction's Avatar
Exactly. The engine turn gasoline and oxygen into carbon dioxide and water vapor, mostly. A little white mist when cold is normal.
So is water dripping from the tailpipe. Small amounts of coolant won't noticeably affect the appearance of the exhaust.
White smoke from a warmed up car, on the other hand...
Old Apr 19, 2024 | 02:17 PM
Most mufflers have a drain hole. But, it is not supposed to drip constantly.
If water is dripping out the pipe all of the time it is coolant leaking into the combustion. 3 ways: the turbo, the oil cooler, the head gasket.
guppy
Oct 8, 2023 07:15 AM
SSROADSTER
43
Mar 7, 2022 08:46 PM
mike1
12
Jun 9, 2015 10:43 PM
heatherbrooker
12
Aug 21, 2014 09:07 AM
ChevyGirl
Apr 6, 2012 02:39 AM
