SS Specific Service Issues/RepairsService/Repairs specific to the SS. Turbo-Brembo Brakes-2.0 Engine-Limited Slip Differential-Programmable Display-MU3 Transmission
[QUOTE=whopper;863966]As Oldblue says "that would not effect the springs, ride height, or the bottoming out.". [/QUOTE}
a loose ball ball joint could cause problems with the motion ratio of the suspension affecting how much spring pressure it takes to suspend the vehicle .
The vehicle is not moving while they are looking at the spring-to-strut relationship, nor while measuring at the fenderwell. No motion, no motion ratio.
Ball joints have absolutely nothing (zip, zero, nada) to do with the distance from the spring "perch" to the strut bearing!
If the spring is shorter than the OE spring obviously the shock absorber will compress. The shock absorber has very little to do with the height of the car; the springs do that.
Saying that the springs "totally collapse" means that the spring have the wrong rate, and the strut bearing is almost touching the spring "perch".
I think the OP is actually meaning that he expected the "lowering springs" to shorten the length of the static part of the strut rather than the travel of the shock.
The bumpers on some after market struts leave little room for shortening. The OE bumper lives under the boot, most replacement bumpers live above the boot.
Sorry but going to have to say this.
Wow nice drugs.
Because Moog does not publish the technical specs anymore (mainly because they are a reseller now, they manufacture pretty boxes not the parts in them). I am sure that someone could take a set of micrometers into a auto parts warehouse and measure every ball joint they could find a fit.
Moog part numbers are still the industry standard. If they don't list a part there is no part number for others to use.
I know this Blue.
But why isn't there another vendor that sells them ?
Who made these ball joints for GM to start with ?
If it was Moog, why not sell them aftermarket ?
