Motor mounts for the ss auto?
Old May 29, 2013 | 11:12 AM
  #111
TurboTechRacing's Avatar
Former Sponsor
It will help at BOTH times you are stating, as it is always controlling the movement of the engine so much better.
Old May 31, 2013 | 12:40 PM
  #112
prod's Avatar
Didnt see it posted here or in the instructions, how are you guys supporting the engine while changing out the mount? Just a jack under the oil pan, with maybe a piece of wood to prevent damage? I wouldnt want to crack/dent the oil pan or compress the gasket and cause a leak.
Old May 31, 2013 | 01:20 PM
  #113
IgottaWoody's Avatar
yeah..something softer then the pan on a jack works fine...actually needed to shift around when installing as it helps get the bolts aligned..
Old May 31, 2013 | 02:02 PM
  #114
prod's Avatar
Thanks, do you happen to know the torque specs for the bolts and nuts?
Old May 31, 2013 | 02:14 PM
  #115
they are in the instructions
Old Jun 1, 2013 | 09:45 AM
  #116
prod's Avatar
hmm.. mine just says refer to manufacturer.
Have them handy?
Old Jun 3, 2013 | 07:26 AM
  #117
Former Sponsor
I dont have a manual in front of me, I will search around and see if I can locate them. Otherwise you could call a local GM dealer and ask :)
Old Jun 3, 2013 | 12:43 PM
  #118
prod's Avatar
Found it. Engine mount to body side rail nuts: 74 lb ft, engine mount to engine bracket bolts: 37 lb ft
Old Jun 6, 2013 | 10:02 AM
  #119
Former Sponsor
Thanks for posting it up!
Old Jul 28, 2013 | 01:53 PM
  #120
Former Sponsor
In stock ready to go!
