Mounted ss rotors without changing caliper!
Old Dec 5, 2018 | 09:45 PM
d0sitmatr's Avatar
The stock brakes should not fade badly , the rotors should not warp. These issues are usually a result of rear brakes that have not been kept properly adjusted .
pairing them up next to my other cars (protege5, sentra, altima and civic) they have horrible fade and far less grip. I asked my mechanic to check things out and everything is working correctly, just weak brakes in my opinion.
as for the warping, my mechanic explained it as this, whoever replaced the brake pads previously, didnt put any grease on the pins, thus not allowing the calipers full freedom of movement, so they stayed clamped longer than they normally would have.
typically, I would do a brake job myself, but as he was looking at an issue Im having in another area already, and I had the pads on hand, he went ahead and put them on for me today. anyways, once I get the newer calipers and rotors on, Im going to have him manually adjust the rear drums as well, just to cover my bases
Im still having a little bit of an issue with identifying the correct brackets, does anyone have a link to part numbers for the specific brackets I need ?
Old Dec 6, 2018 | 07:56 AM
A great how to.....
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
and part numbers
Old Dec 6, 2018 | 08:23 AM
d0sitmatr's Avatar
awesome, thank you !
for the record, I know I can use the search function, and have, the problem is I suck at it, Ive never been good using search engines, maybe I use too literal phrasing or too vague, or.... I dont know, I just always have issues with using search functions.
so I apologize for asking questions that I know have been answered.
Old Dec 6, 2018 | 08:26 AM
No problem, thems the brakes!
Old Dec 6, 2018 | 08:43 AM
This sites Search Function isn't that bad..........if done correctly.
Change the default search box from Threads to Google Search and you'll get much better results.
Old Dec 6, 2018 | 08:56 AM
  #26
d0sitmatr's Avatar
a perfect example of why I suck, I honestly didnt even know that was possible... and Im not dumb (unless you talk to my wife), Ive been working with comps since mid 90s and building them since 98... but that is hardware lol
djw2122000
Mar 14, 2014 10:21 AM
TEB-HHR
Oct 10, 2011 11:34 AM
Black Beauty
Jul 29, 2007 09:17 PM
bigallis1
Apr 25, 2007 06:00 PM
upOnGamE
2.4L Performance Tech
12
Sep 15, 2006 01:09 PM
