New filter throwing codes
Old Mar 28, 2011 | 12:27 PM
Martial Law's Avatar
Im glad I could provide a great way to vent. Its a win win. You got to rant and I got some info. Thanks.
Old Mar 28, 2011 | 02:20 PM
OK, I want a tune. What route should I go? Do I buy the HP tuners vcm suite and fiddle with it at home or should I send the info and do Trifecta? Any other options?
Old Mar 28, 2011 | 03:04 PM
bartSS's Avatar
I would have someone tune you with HPTuners and do a real street tune.
Old Mar 28, 2011 | 03:47 PM
rallycobalt06's Avatar
screen name: Area47
real name: Bryan Higgins
look him up on cobaltss.net and send him a PM. he's quite possibly the best Cobalt (same as HHR) tuner out there and i believe he lives in the Kansas City area. he uses HPTuners.
Old Mar 28, 2011 | 03:50 PM
Thanks. I have family out there. Six hours from where I am at and I wont have to pay for a hotel.
Old Mar 28, 2011 | 04:04 PM
My wife had a 07 SS cobalt SC so I am familiar with the forum. Now I just have to wait for the ss.net forum to allow me to send him a message.
Old Apr 6, 2011 | 03:37 PM
berky1976's Avatar
Listen to him
Originally Posted by bartSS
If youre not tuned for it no matter what you do the code will keep coming up and the car will go into limp mode (if it hasnt done so yet). Find a local tuner with HPtuners and have them take care of you. But if an intake is all you have and will have then i would just get rid of it and leave the stock one on.
I have a cold air intake sitting under my bed because i put it on and had the same problems you did. It was good for like 2 days then it would throw the code like 5 times in a 10 mile drive. So for now its a nice paper weight until i tune for it.
Listen to BartSS, I had the EXACT same problem you are having when I swapped out the paper with just a K&N and then again when I swapped out the whole intake box... as he told me, some SS' just code when the filter is swapped. I read more on it in my repair manual that I just got on the HHR for the code P0101 which is the same as I got. It relates to the ECU not seeing specific readings within a calibrated range that it doesn't like and that causes the issue. If you go back to the stock paper, you'll lose the code probably within three cycles like I did and get your boost back if you were losing it. The dealership couldn't even figure that out. It took me less than a day to find the solution on here once I could post a thread. Unfortunately if you aren't going to tune like BartSS said then you'll just have to go back to the stock set up to get the car back to normal. As for those saying you needed to swap the MAF sensor, the dealership swapped mine twice and it didn't fix the issue, because it is the ECU that is expecting a specific range from the MAF and when it doesn't see it, bing.... CEL comes on. So, unless you plan on tuning your ECU then I'd just get your money back from the filter/intake manufacturer and call it a day.
Sorry Rally, I should have gave props to you as well. You were right there with BartSS on the issue as well.
Old Apr 6, 2011 | 07:40 PM
Thanks for the info. I am currently waiting for my exhaust and I am going to order my inter cooler piping and other bolt-ons so I can get a tune with HP tuners. I have an experienced tuner waiting to fix me up.
Old Apr 7, 2011 | 12:02 AM
foolmoon_design's Avatar
....And void your waranty! Do GM first, then someone else.
LolaIsMyHHR
Jan 14, 2015 10:16 AM
Happy13178
Dec 29, 2014 09:08 AM
Hubbcapp
Jun 26, 2014 02:17 PM
SwaintaN
Dec 13, 2013 09:48 PM
59caddy
Jan 26, 2013 12:49 AM
