no boost is back.
Old Nov 9, 2011 | 09:01 AM
galtjunk's Avatar
no boost is back.
GM turbo upgrade was installed a couple of years ago.
Last winter I had a problem with boost.
It's back and it has something to do with cold weather and right hand turns.
It worked fine all spring, summer and fall.
I warm the car up.
I leave my driveway, proceed to a stop sign and make a right turn.
I can only get 5 psi. I reach another stop sign and stop.
I turn left. It will boost to 21 psi.
I make another left and it still works with or without having to stop.
I come to another light. I turn right. 5psi. Auto shifts to second and still only 5 psi. It will give me the full range of rpm but no boost.
If I back out of it and nail it, it will give me full boost.
This is now happening every day and it only started when it got cold.
There is never a check engine light.
Old Nov 9, 2011 | 09:39 AM
I'm not Mr. Goodwrench,... but when mine was acting like that, they replaced the lower sensor and installed a bracket to hold the cold side pipe from moving. This eliminated the rub when the engine moves. The dealer made it. Thats what I would do, good luck I know the 5lb boost thing cause I drove it while we were waiting for the new sensor to come in. Very slowly
Old Nov 9, 2011 | 09:44 AM
ATLsilverSS's Avatar
^^^^think you hit the nail on the head mr goodwrench
Old Nov 9, 2011 | 06:06 PM
Victory Red SS's Avatar
Try adjusting lower TMAP for clearance and TTR solid engine mount. Helped me.
Old Nov 10, 2011 | 08:33 AM
foolmoon_design's Avatar
Everybody has issues with rubbing. SS that is awesome that your dealer did that! In my case I flipped the T-Map 180* when putting on the cold pipe. works like a charm.
1900colt
Mar 31, 2014 12:55 PM
gmdealerguy
11
May 10, 2010 09:51 PM
Ambivalence
Dec 23, 2009 10:18 PM
hyperv6
Sep 11, 2008 06:57 AM
hurst equipped
Aug 15, 2008 11:05 PM
