No crank No start (sometimes)
Old Jul 5, 2024 | 01:13 PM
BlackSS09's Avatar
Originally Posted by donbrew
"No crank" means the starter motor is not activating.
The "sometimes" makes me think either heat related or loose wire.
I believe it’s heat related too. The only code I have in my car is actually a P0601 check sum PCM code. I believe is the Pcm is getting too hot. When I take the pcm out and let it cool down and put it back it starts right up every time and the code goes away for awhile until I drive it for some time again. Just to double check the pcm is the part number 12629313 and is in front of the fuse box?
Old Jul 5, 2024 | 01:22 PM
Did you disconnect the ECM while the battery was still connected? That may have caused the problem
https://www.obd-codes.com/p0601
thats where it lives , ye
these guys can help you
https://www.fs1inc.com/catalogsearch/result/
Old Jul 5, 2024 | 02:48 PM
BlackSS09's Avatar
I was wondering if there was any other trusted sites that I could buy an ECM from. I placed an order with flagship one like 3 weeks ago they said it would take a 1-2 weeks with programming and shipping. It still hasn’t even been shipped I also have seen a lot of bad reviews saying the same thing and that then when they did receive their module it was faulty. So I refunded it I don’t care if the module is already programmed or not I have a place that can. But if anyone can point me anywhere that’s trusted it would be much appreciated.
Old Jul 6, 2024 | 02:14 PM
If you can get it programmed, key in the part number and pick up used one from eBay or any other site.
https://store.allcomputerresources.c...-computer.html
Old Jul 6, 2024 | 03:06 PM
The code goes away because disconnecting the ECM clears the codes.
In your first post, you suspected the neutral safety. Is this a manual or automatic transmission?
scrambler
Aug 25, 2021 06:27 AM
Delton
Jul 29, 2020 05:11 PM
bchappelow
Jan 31, 2019 11:16 PM
09hhrproblems
Nov 16, 2017 11:06 AM
nitronut67
7
Feb 4, 2016 09:55 AM
