overheating
Old Feb 20, 2011 | 07:54 PM
jonboyb's Avatar
Apparently I have a bad relay as well...but the other direction. My fan now kicks on at 194 so basically it runs all the time. I have extended warranty to 72k and I'm at 51k now and I'm actually considering waiting till it burns out the fan and get them both replaced. I don't know how long it's been cutting on too early and I fear the fan life has been greatly reduced but till the fan actually dies I know GM won't replace the fan out of good faith.
Old Feb 20, 2011 | 08:24 PM
Michael20832's Avatar
My fan went out totally this past july temp gauge went to red luckly i was on my way to work and only 2 miles from dealer. Then relay was sending bad code on and off it would come on and then clear itself so i put off going to dealer plus i thought it might be my air intake. After i installed OEM air box to see if i still get code and after 2 weeks the code came back till finally it stayed on and didn't go away i took it to dealer that extended warranty helped alot. Already got a call to dealer warranty dept to extended it further.
Old Feb 25, 2011 | 08:33 AM
Originally Posted by roadking
I have 08 hhr ss 2.0 motor running hot while sitting at idle ,also noticed cooling fan not coming on to cool when reaching cut on temp any advice out there
roadking,
I will be sending you a private message shortly for more information.
Tricia, GM Customer Service.
guppy
Aug 24, 2015 07:29 AM
batsibf
2.4L Performance Tech
14
Apr 26, 2015 11:22 AM
cturboaddict
Aug 18, 2013 09:15 PM
Mr Z
Jul 27, 2012 05:26 PM
TxSkyPilot
Jan 28, 2008 04:54 PM
