Please help boost issue
No I only replaced it once but I was giving it some time to drive and what I mean by that is when I Floor it going to boost it'll run up to 25-30 you hear the turbo spool but it's only for a couple seconds and then it drops back into vacuum its kind of like a limp mode but there are no codes
I replaced the boost solenoid and it's still doing the same thing and the cel came back on with a regular code- p2261 and a continuous code p0234 - I starting to really think the wastegate ? Ideas or thoughts
You alternate between no codes and there are codes. Which is correct?
Do you understand how the codes work and the difference between "regular code" and "continuous code"? If not, it might be easier for you to re-read the booklet that came with your code reader. We can attempt to explain here, but the terminology is different from maker to maker and you may just get more confused.
The P2261 seems to pertain to the bypass valve per this thread
P2261 - Turbo/Super Charger Bypass Valve - Mechanical
The P0234 is wastegate related per this thread
http://www.obd-codes.com/p0234
I would give it 3 cold start cycles and then check it.
If the p0234 does not re occur, in several cycles it should clear. I don't know how many.
If the p2261 does re occur it will become permanent.
At least that's what happens with most codes.
Ok let me Try this again after I replaced the solenoid and cleared codes went on test drive floored it in 5 th and it built boost up till 25 psi then suddenly dropped down and would only build 2-4 psi and the cel came on hooked my code reader up - cheap. Code reader from O'reillys and found the 2261 and 234 over and under boost codes .
