Please help boost issue
Old May 6, 2016 | 05:40 PM
Originally Posted by SHAGGYMEOW
No I only replaced it once but I was giving it some time to drive and what I mean by that is when I Floor it going to boost it'll run up to 25-30 you hear the turbo spool but it's only for a couple seconds and then it drops back into vacuum its kind of like a limp mode but there are no codes
Oh, ok I get you now. Yes, we are saying the same thing, the turbo cuts out after 3 seconds. The link donbrew provided in post #9 has good information about this issue. It very likely is the boost control solenoid, in the picture I provided. The only thing I can't figure is why there are no codes.
Old May 7, 2016 | 08:37 AM
Check the link I posted in #3
Old May 18, 2016 | 10:54 AM
SHAGGYMEOW's Avatar
I replaced the boost solenoid and it's still doing the same thing and the cel came back on with a regular code- p2261 and a continuous code p0234 - I starting to really think the wastegate ? Ideas or thoughts
Old May 18, 2016 | 11:45 AM
You alternate between no codes and there are codes. Which is correct?
Do you understand how the codes work and the difference between "regular code" and "continuous code"? If not, it might be easier for you to re-read the booklet that came with your code reader. We can attempt to explain here, but the terminology is different from maker to maker and you may just get more confused.
Old May 18, 2016 | 01:14 PM
The P2261 seems to pertain to the bypass valve per this thread
P2261 - Turbo/Super Charger Bypass Valve - Mechanical
The P0234 is wastegate related per this thread
http://www.obd-codes.com/p0234
Old May 18, 2016 | 01:31 PM
  #26
But, some historic codes will clear themselves and some pending codes will go away. That was why my question about understanding codes.
Old May 18, 2016 | 02:33 PM
  #27
So I would suggest to address the P0234 code in this case as it is the continuous code
Old May 18, 2016 | 03:51 PM
  #28
I would give it 3 cold start cycles and then check it.
If the p0234 does not re occur, in several cycles it should clear. I don't know how many.
If the p2261 does re occur it will become permanent.
At least that's what happens with most codes.
Old May 19, 2016 | 09:27 AM
  #29
Like this:
File Type: pdf
Old May 19, 2016 | 05:16 PM
  #30
SHAGGYMEOW's Avatar
Ok let me Try this again after I replaced the solenoid and cleared codes went on test drive floored it in 5 th and it built boost up till 25 psi then suddenly dropped down and would only build 2-4 psi and the cel came on hooked my code reader up - cheap. Code reader from O'reillys and found the 2261 and 234 over and under boost codes .
