Pop goes the chain guide
Old Apr 13, 2022 | 11:28 AM
PulpFriction's Avatar
Originally Posted by fastsuv
I just wanted to update everyone on the fix.
I replaced the chain and the guides.
It runs great again.
The front guide was busted into pieces.
The timing was off quite a bit - possibly 2 or 3 teeth. I was surprised as it still idled (with a miss) and ran but at low power.
I thought for sure engine damage after seeing how far off it was, but it runs great now.
Some people who get the code and then the engine won't run must have the timing off even worst.
Steve
Thanks for the update. No new timing chain tensioner? Did it seem OK? (Presumably if you didnt replace it you reset it.)
What did the front guide look like? Shattered or just one break, for example? I’ve seen two versions of that guide, one marked Cloyes, that was ordered separately as a Genuine GM part and came packaged as such, and one marked GM and their part number, which came with my Cloyes timing set. Not making this up. The design of the gussetting was slightly different too.
Did you reuse the crank sprocket both times?
Old Apr 13, 2022 | 11:54 AM
fastsuv's Avatar
I did put in a new tensioner. The old one seemed fine, though.
I reused the crank sprocket both times.
The front guide had broken into 3 or 4 pieces.
I didn't look at the front guide closely to compare it to the old one (or pieces of the old one!).
Steve
Old Apr 14, 2022 | 08:14 AM
From Installation Tip: Ecotec 2.0L, 2.2L, 2.4L : Chain/Tensioner (cloyes.com)
68Chrgr
Maintenance and Upkeep
25
Oct 4, 2025 07:33 AM
will1528
Feb 26, 2022 02:42 PM
billbryant
Aug 6, 2019 09:52 PM
Hot Bite
Aug 20, 2018 06:58 PM
fastsuv
Oct 16, 2014 07:29 PM
