Power Lumbar Support not working
Old Aug 9, 2013 | 01:01 PM
chevyss's Avatar
I have a 2009 HHR SS that has a bad power lumbar support. When I press the switch, I hear a very faint motor noise and the support hardley works. The car is out of warranty, and I am wondering if I could replace the electric motor myself? Is it difficult?
Also, is the lumbar support operated by a pump or a set of gears?
Thanks for your help!
Old Aug 9, 2013 | 01:07 PM
solman98's Avatar
Years ago I installed some factory GM unit's in my truck. Air bag, pump and switch. Sounds like you just have a weak pump. Should be on the bottom of the seat.
Old Aug 9, 2013 | 11:34 PM
chevyss's Avatar
Thanks for the reply solman98. After I posted the message, I managed to find an exploded view of the drivers seat. At first, I thought it was an air bladder that served as the lumbar support but I was mistaken. The lumbar support consists of a horizontal bar that creates a lower bulge in the seat when the switch is actuated. Also, I found out that the lumbar support assembly consists of a bar and motor that is geared, and is available as a seperate piece from the dealer. Cost is under 200, but its a big job because it looks like the only way to do it is to remove the seat cover.
When I get a chance, I am going to remove the seat back again and snap a picture to post it on the forum in case anybody else is having problems.
One last thing, after checking out the assembly I am thinking that it might be a better idea to slide forward a bit when your increasing the support in order to reduce the stress on the motor and lumbar support assembly.
Old Sep 17, 2013 | 06:31 PM
bad03xtreme's Avatar
Mine quit working today, did you ever repair yours?
Old Sep 27, 2013 | 10:52 PM
87silver's Avatar
I have an '08 SS. Never checked for any type of lumbar adj. I never saw it on the RPO list. Is it standard?
Old Sep 28, 2013 | 08:08 AM
Musicguy's Avatar
It is I believe. It's one of the toggle seat adjust buttons. Mine on occasion won't work either, but inconsistently.
Old Oct 5, 2013 | 10:16 PM
chevyss's Avatar
HHR Lumbar Support
I checked mine again and it appears to be working fine. Btw, the assembly for the power lumbar support costs about $150. The switch for the lumbar support is located about mid point on the left side of the seat and is a switch that rocks or toggles in both directions. If you want to see the assembly, you carefully pull off the plastic back to the seat. I haven't been checking the forum lately because it turned out to be fine. Also, contrary to my believe, its not an air bladder but rather a motor that moves a bar up and down to created a bulge in the seat that acts as a lumbar support. If I get the time and ambition I will remove the panel from the driver's seat and snap some pictures.
If it does go bad btw, its a hell of job by the way!
ImNewHere
May 27, 2014 11:05 PM
edgarfrog
Mar 5, 2014 08:11 AM
Rocket88
Sep 2, 2012 12:58 PM
Roadkill
Sep 25, 2009 05:01 PM
James06
Aug 30, 2006 11:56 AM
