Rear Caliper Parking Brake Srpings?
Old Dec 27, 2020 | 05:54 PM
LazyLemming's Avatar
Originally Posted by donbrew
The correct tool is the little block tool.
Already got one in my cart... now just trying to figure out if this can be fixed without replacing the caliper...
Old Dec 27, 2020 | 06:54 PM
It should just be an adjustment.
Old Dec 27, 2020 | 07:05 PM
Thankies!
I lied, I'm not checking it tomorrow, it's cold as fark and snowing tomorrow. I'll work on it next warm streak we get.
Appreciate the help, I won't make that mistake again >.<
Old Dec 27, 2020 | 08:43 PM
And check the cable tension
Old Dec 29, 2020 | 01:02 PM
Cat Man HHR's Avatar
Originally Posted by LazyLemming
I just used a standard compression tool, literally this thing right here, to compress the piston back into the caliper.
https://www.autozone.com/test-scan-and-specialty-tools/brake-tool/oem-loaner-disc-brake-caliper-tool-57111/298604_0_0?cmpid=PLA:US:EN:AD:NL:1000000:TLS:71700 00004379874
Did my rear brakes 3 months ago and used the same tool.
It rotates the caliper piston and pushes it back in.
Before pressing on the brake pedal pulled up on the E brake a couple of times to let the piston ratchet out if needed.
No problems at all.
Was the old pad wear even on the left and right ?
Bonez
Oct 27, 2025 04:56 PM
Bonez
May 31, 2024 07:57 AM
rnmodes
7
Nov 30, 2016 02:59 PM
canroc
Jun 23, 2013 07:33 AM
domer94
Oct 25, 2012 02:58 PM
