Rear Calipers
Old Jun 6, 2020 | 03:35 PM
fastsuv's Avatar
Rear Calipers
One of my rear calipers is leaking a bit.
Since I am going to paint all the calipers anyway, I want to buy a pair of new rear calipers and paint them before I put them on.
Rock Auto shows a whole bunch of different calipers (reman, reman coated, new, Centric, Raybestos, AC Delco,etc).
Any recommendations?
Also, any recommendations on caliper paint? Local Dupli-color kit? Fancy Eastwood kit ($)?
Steve
Old Jun 6, 2020 | 08:26 PM
This Power Stop kit from RockAuto is complete, they used to offer powdercoat, but I see that’s for a set of fronts or front and rears non Brembo
https://www.rockauto.com/en/catalog/...+pad+kit,14204
as for paint, your choice of Eastwood or Duplicolor or other High temperature paint
Old Jun 8, 2020 | 12:06 PM
Lethal Tendencies's Avatar
I really like the duplicolor brush on. It has a nice glossy bright finish.
Old Jun 8, 2020 | 01:08 PM
geg's Avatar
geg
Originally Posted by fastsuv
...Rock Auto shows a whole bunch of different calipers (reman, reman coated, new, Centric, Raybestos, AC Delco,etc).
Steve
The calipers is a fairly simple product, any of the listed manufacturers will offer a quality product for you.
I would choose Rabestos for the combination of price / quality. Of course, AcDelco is the official conveyor supplier. But expensive in my personal opinion.
... Also, any recommendations on caliper paint? Local Dupli-color kit? Fancy Eastwood kit ($)?
Steve
For painting calipers it is advisable to use high-temperature paint. Something from what paint furnaces or boilers. You will find a lot of options in the building materials store. Give preference to primer-enamel, carefully read the instructions, find confirmation that the enamel can be applied directly to the metal.
Old Jun 12, 2020 | 03:21 PM
letterman7's Avatar
Hmmm.... the premium version, the KC1610, shows the caliper brackets as well. I want to assume that, if ordering that kit for a non-SS buggy, those brackets would work with the existing spindles, yes?
Old Jun 12, 2020 | 04:40 PM
LS/LT spindles do work with the SS non Brembo 11.6 inch caliper brackets and rotors.
the SS calipers are a smaller bore.
Old Jun 12, 2020 | 04:45 PM
letterman7's Avatar
Right. I'm assuming that what RockAuto has are replacements for non-Brembo SS cars, so if I'm upgrading front rotors (don't need the calipers, but hey) on my LT, that kit has the correct brackets for the wider rotors?
Old Jun 12, 2020 | 07:21 PM
The rotors are larger in diameter, here is a great explanation
https://www.chevyhhr.net/forums/www....ad.php?t=42938
and yes the set you referred to will fit . Check out the Power Stop kit with powder coating
Alexwsilver2010
12
Mar 15, 2012 06:39 PM
jas89tta
16
Sep 18, 2009 12:20 AM
JayKWills
17
May 6, 2009 12:02 AM
cjuetten
22
Apr 4, 2009 06:26 PM
dpoll995
May 4, 2008 09:02 AM
