Replace cam chain without removing cam phasers?
Old Sep 3, 2021 | 03:10 PM
DoctorZ's Avatar
For those who have replaced the cam chain & tensioners on an SS, can the cam chain be removed without removing the cam phasers/sprockets? Not sure if i should hold off starting the job until I order the torque-to-yield bolts, or if I won't need to remove the cam phasers.
Old Sep 3, 2021 | 05:25 PM
You must remove the phasers, so order the correct bolts. Some timing chain kits come with the cam gears and bolts but are not compatible with the VVT engines 2.4 2006 thru 2011 , 2.0 2008 thru 2010 and the 2.2 2009 thru 2010
https://www.chevyhhr.net/forums/how-...in-kits-60394/
The 2006 thru 2008 2.2 did not have VVT.
As this is about the SS 2.0 have a good read thru that thread
Old Sep 3, 2021 | 05:29 PM
And make sure you set your phasers to stun...
Old Sep 3, 2021 | 05:51 PM
The cam shafts must be timed prior to disassembly. Do not rotate the crankshaft counter clockwise.
Old Sep 3, 2021 | 08:06 PM
You only need to remove one of them. Once again, they are not "torque to yield" they are "Prevailing torque". GM "recommends" not "demands" replacing almost ALL of the engine bolts, and then they go on to say just being very sure the threads on both sides are in perfect condition and clean. Too my knowledge there are no "stretch" bolts on the HHR. Not all "torque + angle" fasteners are "torque to yield", that is just a precise way to measure and reproduce clamping force.
Old Sep 4, 2021 | 04:58 AM
DoctorZ's Avatar
Thanks for the inputs. Fortunately a local dealer happened to have the cam bolts in stock so I was able to pick them up late this afternoon. I guess you know how I'm spending my Labor Day weekend...
Old Sep 4, 2021 | 06:34 AM
http://www.ddmworks.com/assets/image...uild%20Kit.pdf
A guide to assemble the chains
Old Sep 8, 2021 | 11:47 AM
PulpFriction's Avatar
I could not get the chain on and off without removing both phasers.
Huh, so the bolts bolts everyone calls TTY not really TTY. I ordered new ones because they were cheap and available, but because the size seems so ample, would have blithely re-used them had I had any trouble sourcing them. THANK YOU, now next time I won’t worry about it.
Old Sep 8, 2021 | 01:57 PM
Price tells a lot. If you replaced every bolt that GM "recommends" you would go broke. Torque to yield is basically the the male equivalent of a squash nut.
https://www.knowyourparts.com/techni...0if%20loosened.
hurst2001
Dec 14, 2019 06:35 AM
1ksprint
15
Jan 15, 2018 11:30 PM
kds
Aug 12, 2015 02:19 PM
cobra94svt
Maintenance and Upkeep
26
Jul 21, 2015 10:31 PM
cobra94svt
Jul 12, 2015 08:02 PM
