Rough idle when on a downward sope
Old May 6, 2012 | 04:53 PM
bad03xtreme's Avatar
I don't drive my car everyday and last week I drove it and someone cut me off in a parking lot and I slammed on the brakes and almost stalled it out. it didn't stall but right after that I stopped at a light that was on a downward slope and it started idling rough and wanting to cut out. I drove it home and it ran fine but today I started it up after it was sitting facing downhill in my driveway and it ran rough and was blowing black smoke when I gave it gas. It drives fine and no issues with boost any ideas?
No CEL's or anything like that, possible evap purge solenoid clogged?
Old May 6, 2012 | 05:00 PM
SmootHHR's Avatar
I killed mine like that about a week ago. Ran like ass for 10 min then fine. You're not alone
EVAP Purge issue or the start of something with the low pressure fuel pump in the tank, it bears keeping an eye on. Eventually it'll pop a CEL if the problem occurs during enough run cycles, but you can always swing by an auto parts store to have the codes pulled because it might have already set one.
Old May 7, 2012 | 02:38 PM
I pulled the solenoid and it was fine so I am not sure what could be the issue. Is it possible it's bad gas? Like I said I don't drive it but maybe once a week.
tiggercross59
Sep 26, 2024 02:16 PM
Azure10
14
Jul 2, 2014 01:59 AM
Highwang
Nov 28, 2013 07:45 PM
F-16C
Feb 22, 2013 07:40 PM
plunger69
Mar 24, 2009 10:53 PM
