RPD stopped working???
Old Aug 7, 2019 | 02:35 PM
Uncle Moe's Avatar
Sorry i guess i should have stated it was a guage out of the Cobalt so the pigtail/ harnwss is opposite..both ends are female the cobalt has a male harnwss coming from. The apillar and the cobalt guage is a female so they work... In an HHR the Apilar has a female and the guagenhas the male..therefoee i have 2 fwmale ends.
Old Aug 7, 2019 | 02:47 PM
Uncle Moe's Avatar
I know you probably knew all of that i figured id juat put that out there lol
Old Aug 7, 2019 | 02:53 PM
Did you see post #2?
Old Aug 7, 2019 | 03:06 PM
Uncle Moe's Avatar
Oh Don you are the greatest!! I didnt see that before and i just left my place... My girl was trying to prove her worthiness to me lastnight by helping me install back seats in my Panell SS and she helped me look for the fuses to fix.. im gonna call her and ask her to see if it works...lol... Should i hahaha..im gonba let u know if that fixed it Don. Thank you so much..ill keep u posted!!
Old Aug 7, 2019 | 05:38 PM
Uncle Moe's Avatar
Hey Don, Thanks for the effort and assistance but unfortunately i changed the #29 fuse even though it dodnt look blown and that made no difference.. still no RPD or DIC. The DIC still shows miles/km, tells me to check my tire pressure and doors ajar but nothing happens when i hit the info button or hold down info and enter button for 2 seconds to try and clear the warnings or turn on/off a specific option. What about removing battery cables and try to "clear" the ecu that way??? Maybe it will reset it or something?
Old Aug 7, 2019 | 07:51 PM
You worked on the electrical without disconnecting the negative cable at the battery.
a full 30 minutes lobotomy might reset the computers
Old Aug 7, 2019 | 07:54 PM
Uncle Moe's Avatar
I know im an idiot sometimes... You know its like my brain shifts into "10yr old boy at xmas" mode and i get all excited and do stupid stuff then regret it later... Im the one who needs the lobotomy lol. So unplug the neg and/or positive cables?
Old Aug 7, 2019 | 08:06 PM
Remove the negative cable clamp on the battery itself.
I thought three 10mm bolts and a harness and the coil pack is out on my 1988 Oldsmobile Cutlass Cierra
the mount touched the positive at the starter and lite up a small fuel leak I was investigating. Burnt that one to the ground!
We all take short cuts, do things that are really dangerous without thinking the repercussions or consequences.
Old Aug 7, 2019 | 08:17 PM
I think you may have fried a data line or a module. Does the engine start? CEL? Disconnect the gauge completely?
Fuses #16 and #7 on the BCM could be involved. The RPD/boost/DIC get power from #16.
I suspect the tan wire (digital signal) got shorted, or you wires mixed up.
Wiring diagram HHR
Cobalt boost
Old Aug 7, 2019 | 08:36 PM
Uncle Moe's Avatar
Don it was fuse #16 brother... It was blown...i changed it and voila!! It works again as well as the DIC...thabk you so much my friend... I was seriously worried i screwed something up badly and u took that stress right off of me... Thank you, for real!!
Jeff
And thanks everyone else for helping me with ideas...i also pulled the neg cable for a half hour Oldblue!! So thanks for the idea!!
