Shock replacement advice requested
Old Mar 28, 2022 | 07:51 AM
RockAuto is a website that vendors sell on not a retailer.
Old Mar 28, 2022 | 07:57 AM
They have a corporate office
https://www.rockauto.com/help/?page=6
They are one of our supporting vendors , so don’t forget that discount code!
https://www.chevyhhr.net/forums/supp...-2022-a-61707/
Old Mar 28, 2022 | 08:49 AM
So do eBay and Amazon.
Old Mar 28, 2022 | 09:13 AM
Yes, I just wanted to point that out. Thanks
Old Mar 28, 2022 | 11:31 AM
DangerBoy's Avatar
So if I order a replacement front hub assembly to replace the one where the ABS sensor has failed, should I do both at the same time? The car only has 100,000 Km (~60,000 miles) on it but it is 14 or maybe 15 years old. How long do those front hub assemblies usually last?
Old Mar 28, 2022 | 11:44 AM
  #26
PulpFriction's Avatar
No. Just replace the failed one. Highly variable life. The original could last longer than an unneeded replacement.
Old Mar 28, 2022 | 11:56 AM
  #27
Or, if one has failed the other isn't far behind. However, much more likely a connector or wire problem since magnets and coils of wire don't usually wear out.
Old Mar 28, 2022 | 12:09 PM
  #28
The variability of bearing life is high too. Lotsa bearing balls in there and if just one spalls or splits…
Old Mar 28, 2022 | 01:32 PM
  #29
Careful ordering, the SS axles are differ size and splines then the LS/LT axles
the SS ANS sensor signals are different also
Old Mar 29, 2022 | 11:45 AM
  #30
DangerBoy's Avatar
@Oldblue I've verified on three other websites that the SKF BR90317 front wheel hub assembly fits the HHR SS only. I'm pretty confident it's the right part. And SKF has a good reputation for making quality bearings. I'm sure it will be at least as good as OEM and IMO there's a good chance it will be of higher quality.
