Something Weird Going On
Old Mar 22, 2018 | 02:13 PM
Gravzy's Avatar
Originally Posted by donbrew
If the CEL is not on stored codes mean nothing. Go ahead and clear them unless you need an emissions within a month or 2.
P0507 is a Type B DTC
Thank you donbrew. I will clear the codes and see if they come back. Do you think back on my first issue that I should be looking at the bypass solenoid due to its only noticeable on deceleration?
Old Mar 22, 2018 | 02:15 PM
Gravzy's Avatar
Don't fall for lower priced thermostats, get the OEM - Thermostat - (2006-2011 All Models)
ACDelco 131-158 GM P/N 12622410
Thanks RJ RS SS 350, I did read on that post you sent me that if you cheap out you will be doing it again. I will be sure to with that one.
Old Mar 22, 2018 | 05:28 PM
I'm going to guess that it has something to do with DFCO. Here is a good post by JoeR about it. https://www.chevyhhr.net/forums/2-4l...e2/#post293975
Old Mar 22, 2018 | 06:38 PM
Gravzy's Avatar
that my friend is the closest I’ve seen thus far to what it may be. This bit is what I found interesting,
• During an extended, high speed, closed throttle coast down--This reduces emissions and increases engine braking.
Doesn't have to be that long (3 sec. noted above), nor high speed. Yes, it does reduce emissions (no gas = no emissions). Engine braking is enhanced.
On a manual trans you can actually feel when the DFCO kicks in. Helps ecomomy, too, since if you aren't putting any fuel into the engine...
I wonder if with one of the sensors that help control that like the MAF, TPS or MAP is dirty or going bad that it would intensify the feeling which is why it feels like a hiccup. I’m going to try this weekend to clean the MAF and see if it calms it down. I’m also going to check for vacuum leaks because I ran a smog test with my scanner and there is a fault with the EVAP system so in hopes with this information and the cleaning and the checks I can tone it down but knowing I will most likely feel something eases my mind some. Thank you so much RJ RS SS 350.
Old Mar 23, 2018 | 02:03 PM
Cat Man HHR's Avatar
An FYI. Our car's have a BPV (bypass valve) not a BOV. They also do have a wastegate.
Bypass valve and wastegate are the same animal. If your talking inside the turbo itself.
Old Mar 23, 2018 | 02:41 PM
  #26
Not the same at all.
Old Mar 23, 2018 | 10:00 PM
  #27
My old stock BPV that has been replaced with the Forge Motorsports aluminum one.
Old Mar 24, 2018 | 04:02 AM
  #28
I stand corrected.
Worked on too many turbo engines that didn't have the bypass valve like the ones pictured. Caterpillar turbo's have a wastegate only and some people would refer to it as a bypass valve also.
JJ_HHR
Sep 22, 2017 06:28 PM
igotgas
12
Dec 17, 2013 09:14 AM
DJNateGnau
Apr 11, 2006 09:29 AM
crazybob
Nov 22, 2005 11:09 PM
