Squealing brakes
Old Oct 10, 2013 | 09:05 AM
jaymz's Avatar
Squealing brakes
2008 SS (non Brembo); 47K. Front brakes squealing (non grinding; non-scraping). Fix? Or replace pads?
Jim
Old Oct 10, 2013 | 03:11 PM
Snoopy's Avatar
I would think the first thing you would need to do is determine what the squeal is..........the wear indicators, pad surface to rotor, "squeal" compound? Then go from there.
However, I would first check both front pads for pad thickness. If they are down to the verticle wear bar (or close to it), I would do a replace job. But that is just me.
Old Oct 10, 2013 | 03:29 PM
be sure to check the thickness of both the inside and outside pads on both the front left and right brakes, they do seem to wear out the inners first!
Old Oct 10, 2013 | 04:25 PM
47k miles. I would at least replace the pads and do a check on everything else.
nacorona
Apr 15, 2013 04:33 PM
bobiroc
Jul 18, 2012 11:39 AM
Retro1949
7
Jan 9, 2012 03:00 PM
meeks22
Apr 18, 2011 07:25 PM
Tony_SS
Jan 9, 2008 08:37 PM
