SS Oil Filler Cap Deconstructed (PICS)
Old Jun 10, 2017 | 07:17 PM
Originally Posted by Oldblue
Six months repair, maybe a different adhesive? Or a long enough fix ,if the OEM cap is on back order.
Yes, a different adhesive would do the trick. If one could find out what cement the factory used, or what materials the cap is made from. It doesn't seem to be PVC. The PVC cement let loose, even though I had run the parts through the dishwasher(so I know they were clean!)
But I can't try another fix, as the internals are now gone.
Old Jun 10, 2017 | 10:13 PM
I think it might be ABS. However "Plumber's GOOP" will stick to most anything even CPVC (Paint bucket).
If you use PVC cement you have to remove the outer skin, that's what purple primer does. Then the plastic welds. So you wouldn't want that anyway.
Old Jun 11, 2017 | 12:09 PM
Blue_SS's Avatar
I would guess the material to be a high-temp nylon with a glass filling. Maybe PA612? It's what's used in most ABS Sensors inside brake hubs...
Old Aug 17, 2017 | 02:38 PM
Got my new filler cap from Summit today. You called it, it's been backordered for a while.
G/M PN 12594232 CAP,OIL FIL(W/SEAL)(VENTED)(ACDelco #FC225)
Interestingly, listed as correct for SS, but 2008 only. The only other SS choice is GM P/N 12583570, which is correct for 2008-2010, but is non-vented. My 2009 was vented, unless someone had replaced it with the incorrect part previously. Seems somewhat unlikely, not impossible.
But 2008, some got vented, some got non-vented? Mid-year change? Why? I don't know.
I'm interested to see what cap y'all have. On the bottom of the cap is a central nub, and a hole or gap on the side of the nub. This is the vent. Maybe non-vented has no nub?
Old Aug 18, 2017 | 11:46 AM
BLKHHRSS's Avatar
I have a 2009 SS and the cap is non vented.
WYWendinger
2.4L Performance Tech
13
Aug 9, 2013 09:50 PM
Dunny
Mods - Engine/Exhaust
Jun 11, 2011 11:59 PM
urbexHHR
Mar 15, 2010 08:45 PM
R CA HHR
Sep 13, 2007 02:33 PM
EL_REY
14
Aug 28, 2006 06:53 AM
