SS operating temp
Old 09-14-2011, 09:56 PM
Chillydip's Avatar
SS operating temp
What is the approx normal operating temp for a 2.0 in 90-100* summer heat?
Chillydip is offline
Old 09-14-2011, 09:58 PM
Hockeylegend117's Avatar
mine normally runs in the low 200s in the texas heat
Hockeylegend117 is offline
Old 09-14-2011, 10:01 PM
Chillydip's Avatar
Thanks Legend. I thought mine might be running warm at low 200's. Guess its normal.
Old 09-14-2011, 10:10 PM
yea on a cool morning its in the high 100s and low 200s in the 120 degree weather we get, depends on how you drive and the driving conditions
Old 09-14-2011, 10:24 PM
mroney's Avatar
Mine also
mroney is offline
Old 09-14-2011, 10:30 PM
2010SilverIceSS's Avatar
Mine ran 190-200 in +90 degree temps in Michigan.
Dave
2010SilverIceSS is offline
Old 09-14-2011, 10:33 PM
ChevyGuySS's Avatar
the thermostat will open at around 195 degrees so the temperature of the engine should be around that too so low 200s and upper 190s is normal. when i put my foot in it for a while mine will get up to about 210 or so
ChevyGuySS is offline
Old 09-15-2011, 12:09 AM
Rainman's Avatar
When I drove to Calif. at the end of June it was about a 110 degrees out and while going over the grapevine my temp went as high as 226 degrees, thats a ton from what it normally runs here, I dont think I've seen it hit 200
Rainman is offline
Old 09-15-2011, 01:02 AM
moonsign's Avatar
Rainman: Going up the "Vine" would build a little more heat than we normally see in the engine. Thats a pretty steep grade and quite long. I think 226 would be about right, and nothing to worry about. Probably droped on the downside pretty quick, I would imagine. "Moon"
moonsign is offline
Old 09-15-2011, 07:02 AM
foolmoon_design's Avatar
Ditto here, driving through the mountain passes here, it goes like 215-219, then back down to 199-203 almost immediately after a crest.
foolmoon_design is offline
Quick Reply: SS operating temp
