Vibration in motor WAWAWAWAWA !
Old Feb 18, 2016 | 01:22 PM
  #31
New timing set with both chains and all the guides & tensioners.
Old Feb 18, 2016 | 01:30 PM
  #32
dhare1's Avatar
Does the motor need to be pulled to do this ? Anything required that will have to be done by the dealer ?
Old Feb 18, 2016 | 02:02 PM
  #33
DrLoch's Avatar
Dealer doesn't have to do it, you can do it.
Heres one post, https://www.chevyhhr.net/forums/ss-s...g-chain-39725/
Heres another, https://www.chevyhhr.net/forums/how-...-rattle-46159/
Some of it decusses the issue you should be able to find a post about the replacement procedure, if not here CobaltSS forum.
Old Feb 18, 2016 | 02:06 PM
  #34
This is helpful, it can be done in the HHR
How To: Timing Chain! - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
And this how to!
Timing Chain Service Procedures GM 2.2L L61 Ecotec, Camshaft Sprocket
This video is also helpful
Take the time to read the how to's and watch the video and ask us if you need to know what tools you're gonna need what parts and so forth
Old Feb 18, 2016 | 02:09 PM
  #35
DrLoch's Avatar
Thanks OB, I knew you'd jump in with a link. Nice job.
Also, if you are stuck on something, ask. A number of people on this site have a lot of experience.
Old Feb 18, 2016 | 02:20 PM
  #36
Well thank you!
Something to listen to whilst you read the how to!!
https://vimeo.com/109988488
Old Feb 18, 2016 | 03:09 PM
  #37
dhare1's Avatar
So there could be a possibility the chain tensioner is failing or failed and put some slack in the chain and it skipped a tooth or a guide broke it will put slack in the chain and could also skip a tooth ? So if the two balance shafts are out of timing it will cause vibration . I think I have a better understanding now . Thank you everyone , you have been very helpful , might take some time but I'll keep you posted.
Old Feb 18, 2016 | 03:33 PM
  #38
DrLoch's Avatar
If you have eliminated the the external things that leaves internal. Checking the the balance shaft timing is a start.
Just so you know, a spun bearing/rod will start making a load noise at around 2K RPM as well.... that being said it would be easier to pull/drop the motor.
Old Feb 18, 2016 | 04:58 PM
  #39
dhare1's Avatar
Will you guy's agree that I take it apart(timing chain cover and cam cover) and inspect all of the parts for wear and check all timing marks before I order the parts ? If timing looks good and nothing is loose or broken then I should put it back together and eliminate the balance shafts as the problem ?
Old Feb 18, 2016 | 05:12 PM
  #40
My Haynes manual says to take note that you can remove the chain, but the balance shafts themselves can only be removed from the engine block after the engine has been removed from the vehicle.
